Toyota automatic gearboxes- educate me
Flash
 Share
I know that a lot of the older manual Toyota gearboxes like the W and G series have bell housings that can be swapped out to suit a particular Toyota engine. Do the auto gearboxes like the A43D and A44DL have the same ability ?
Yeah what engine etc. Some will be harder to track down a bell-housing that others.  People threw away the A43 etc autos like crazy but they are pretty good units, a overdrive and lockup version without computer control being the holy grail.
Thanks fellas.
The engine I want to put it behind is a Toyota 3Y out of a mid '80s HiAce van. According to some info I found on The Google it looks like these vans were equipped with either a A44DL or a A45DL. The box was top hung in the vans.
@Spencer I seem to recall that you are Brissy based - correct em if I'm wrong. If you know of any available units in the Brissy area, please let me know. Ta
From wiki
A43D
Four speed automatic without lockup torque converter.
This transmission model is not electronically controlled. It is instead controlled by throttle position and also by a governor.
Manufacturer designation: Aisin Warner 03-71
Applications (calendar years):
  • 1981 Toyota Celica Supra
  • 1982–1985 Toyota Celica XX 2000G/S turbo
  • 1982–1985 Volvo 240 2.1L Turbo I4 (AW71)
  • 1985–1991 Volvo 740 2.3L Turbo I4 (AW71)
  • 1985–1990 Volvo 760 2.3L Turbo I4 (AW71)
  • 1985–1990 Volvo 760 2.8L V6 (AW71)
  • 1988–1991 Volvo 780 2.3L Turbo I4 (AW71)
  • 1987–1990 Volvo 780 2.8L V6 (AW71)
  • 1991 Volvo 960 2.8L V6 (AW71 – Australia only)
  • 1991–1995 Volvo 940 2.3L Turbo I4 (AW71)
  • 1981 Toyota Pickup 2WD 2.4L I4 22R (California emissions only, Federal emissions used A43)
  • 1982–1995 Toyota Pickup 2WD 2.4L I4 22R/RE
  • 1982–1995 Toyota Cab/Chassis 2.4L I4 22R/RE (flatbed, cube, motorhome)
  • 1995–2000 Toyota Tacoma 2WD 2.4L I4 2RZ
  • 1982 Toyota Crown Royal 2.8L I6 5MG
1 2 3 4 Rev
2.452 1.452 1.000 0.688 2.212
A43DL
Four speed automatic with lockup torque converter. Based on A43D.
Manufacturer designation: Aisin Warner 03-71L
  • 1983–1985 Toyota Cressida
  • 1982–1985 Toyota Land Cruiser
  • 1982 Toyota Celica Supra
  • 1990–1992 Volvo 740 2.3L Turbo I4 (AW71L)
  • 1991–1997 Volvo 940 2.3L Turbo I4 (AW71L)
A43DE
Four speed automatic with lockup torque converter and electronic controls. Based on A43D.
  • 1982–1987 Toyota Cressida
  • 1995-2002 Toyota Granvia
  • 1983–1986 Toyota Celica Supra
  • 1992-up Suzuki Sidekick (4L30E)
  • 1995–1998 Volvo 960/S90/V90 (AW30-43LE)
A44D
This transmission is electronically controlled by an electronic shift control module. Mechanically similar to the A43D.
  • 1989–1991 4Runner
  • 2001–2004 Toyota Tacoma 2WD 2.4L I4 2RZ
A44DL
  • 1982–1991 Toyota Van 3-YE
  • 1989–1990 Volvo 740 GLE 16-Valve (AW72L)
  • 1991 Volvo 940 GLE 16-Valve (AW72L)
  • 1992–1995 Mitsubishi Montero 5 Dr. V43 (03-72L)(V4AW2)
  • 1992–1995 Mitsubishi L300 – (P04v) (P03V)
  • 1992–1995 Mitsubishi Express – (P03V) (V4AW2)
  • 1997–1999 Hyundai Galloper
A45DL
  • 1982–1990 Toyota Van 4Y-E
This document http://www.natpronet.com/trans/A40.pdf says
  • Toyota Vans 1984-89 2WD 4-speed A44DL 3Y-E
 Share
