Popular Post kpr Posted October 12, 2020 Popular Post Share Posted October 12, 2020 Not even my car @Dudley , but is amazing. Ke20 with big block 4k beyond repair. but instead of getting parted or scraped, it lives on 26 1 Quote Link to comment Share on other sites More sharing options...
Dudley Posted October 12, 2020 Share Posted October 12, 2020 Alright let’s see those questionable modifications. Featuring @ajg193 signature lift kit Quote Link to comment Share on other sites More sharing options...
kpr Posted October 12, 2020 Author Share Posted October 12, 2020 @ajg193 got nothing on whats to come... Setting the scene still; After some paddock basing, it went something like. quote @Dudley "its over heating gonna go in" nek minute see the GC heading towards jump i built for the hilux, then proceeding to jump said jump. 6 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted October 12, 2020 Share Posted October 12, 2020 I hope that video isn't with the lift kit, it's lower than my car 1 1 Quote Link to comment Share on other sites More sharing options...
Dudley Posted October 12, 2020 Share Posted October 12, 2020 Hey buddy can you please keep your comments to the discussion thread. Bloody starlet people 2 1 2 Quote Link to comment Share on other sites More sharing options...
Dudley Posted October 12, 2020 Share Posted October 12, 2020 6 Quote Link to comment Share on other sites More sharing options...
Dudley Posted October 12, 2020 Share Posted October 12, 2020 3 2 2 Quote Link to comment Share on other sites More sharing options...
Dudley Posted October 12, 2020 Share Posted October 12, 2020 3 1 Quote Link to comment Share on other sites More sharing options...
Popular Post kpr Posted October 12, 2020 Author Popular Post Share Posted October 12, 2020 So then old mate @Dudley with one too many clutch kicks snaps an axle. then winter comes along, so been parked up for many months. fast forward to now'ish. the paddock drying out and the gc begging for some upgrades first up the front shocks. still had the og toyota shocks in the stuts. which means can be pulled apart and modified cut the internal stop off and welded it back on 40mm lower down done some janky mods to the valving in the shocks so has more compression valving. plus ae85 springs = 40mm more travel. 9inch in total got em in there just full droop, should be enough to pass a cert on the ground, pretty much textbook offroad spec 50/50 droop compression 14 1 2 Quote Link to comment Share on other sites More sharing options...
Popular Post kpr Posted October 12, 2020 Author Popular Post Share Posted October 12, 2020 I wanted to make some getto bypass shocks for the rear. but the shocks i had hanging around wern't long enough. soo getto hydro bumps instead yep thats a hilux front shock with 4age valve springs to return the shock. 50mm travel, take off the factory bumpstop and should have another 30mm or so up travel as well some more butchery required but will go here somewhere 19 1 2 Quote Link to comment Share on other sites More sharing options...
Popular Post kpr Posted October 31, 2020 Author Popular Post Share Posted October 31, 2020 Had a little accident before first test run. they were a bit close to the ground . so yeh fail. think they would have done ok, if made it into the paddock and not hit bit of concrete on side of driveway haha enter v2 these were front strut inserts. so bigger shafts. sealed gas shocks, you know the ones that say dont open or heat. i did neither of course. they are twin tube, so the outside bit just holds oil and nitrogen pressure. they have a pretty basic shimstack that bolts to end of shaft. i drilled out the rebound bleed holes and modified the shim to bypass more oil on rebound. done this so they return faster. plus the other butchery can plainly see in pic. the only real pain in the ass was the seal at the top. it just pushes up against the outer housing. so i had to preload the housing when welding them back together. put 90psi compressed air in them. one had slight leak with air in it alone. but seemed to fix itself once put oil in them. So.. they actually act like real hydro bumps. as the shaft goes in it compresses the air more and acts like a spring. along with the compression valving. the dumbed down rebound valving lets them pop out fast but not too fast, so shouldn't push the car back up. should be able to mess with oil level and air pressure to make them harder of softer if dont explode first. they have 50mm travel 18 Quote Link to comment Share on other sites More sharing options...
Popular Post kpr Posted November 22, 2020 Author Popular Post Share Posted November 22, 2020 awwww unluggy 24 2 7 Quote Link to comment Share on other sites More sharing options...
Popular Post kpr Posted November 22, 2020 Author Popular Post Share Posted November 22, 2020 suspension was on point tho. till it broke. think a shock blew out aiding to the rollover. this wasn't the biggest jump.. 18 8 Quote Link to comment Share on other sites More sharing options...
kpr Posted November 25, 2020 Author Share Posted November 25, 2020 @Dudley trying to flex on us with his extended lca with fresh black paint. probably got a ndt crack test done as well Oh an yeah the car isnt that broken, just lca poped tyre, and shock needs more oil, maybe seal stuffed. Hydro bumps worked good. watching the roll in slow mo looks like the steering arm over centered and the wheel jamed, along with lack of oil in shock done the weird bouncy thing and over she goes. extended lca's should make it a bit more stable and get rid of some of that positive camber when suspension droops 8 Quote Link to comment Share on other sites More sharing options...
Dudley Posted November 25, 2020 Share Posted November 25, 2020 Let’s clarify things. My arms are the bottom ones 1 Quote Link to comment Share on other sites More sharing options...
kpr Posted November 25, 2020 Author Share Posted November 25, 2020 dunno the top ones look better? Quote Link to comment Share on other sites More sharing options...
Dudley Posted November 25, 2020 Share Posted November 25, 2020 Yea cause I made em Quote Link to comment Share on other sites More sharing options...
xsspeed Posted November 26, 2020 Share Posted November 26, 2020 is this a project thread or a discussion/i love the spare forlornly falling out after the roll 1 Quote Link to comment Share on other sites More sharing options...
kpr Posted November 26, 2020 Author Share Posted November 26, 2020 dont forget the battery falling out the other end. and yeah nar this isn't the discussion thread this is: 2 1 Quote Link to comment Share on other sites More sharing options...
