Hi guys, I'm looking for recommendations for a person or company to do some work on my daily, 2004 vw transporter t4.  I need the duel mass flywheel and clutch replaced. I had a quote from a vw specialist for $2700. I quite literally can't afford this.
So any recommendations from you good folks? Or is $2700 What it's going to cost?
Thanks, David
Doesn't sound that horrific, does it need a new flywheel or do they replace with every clutch? Or is there a non dual mass one that will fit?
Anything Mechanical in Hornby and there is another out that way I can't remember the name of for some reason I used to take Mercedes Sprinters to,  the agents used to send me there.
I'll update if it returns to me during the day.
Thanks, David
Probably better to use the vw specialist as they will probably be the quickest, in saying that it's actually a pretty easy job.
How much have they quoted you for parts?
Unfortunately today was a non stop day at work. So no time to do anything. I need to phone the vw specialist back for a break down on the quote.
The job doesn't sound horrendous, but having  a fully stocked workshop would be benefical! It's a little bit different to the Vauxhall viva!
I will give the recommended places a ring tomorrow!
Thanks guys!
A little update, turns out the cost of the parts is the biggest issue. So parts will be ordered from the UK and I have a garage lined up to do it!
Thanks for your input!
