  • Replies 153
  • shizzl
    154
Ill be creating its on build thread shortly as its quickly overtaking the hunter .
Although that should be running over the xmas break.
  • Like 8
Punched a hole through the firewall for the loom.
Its safely grommeted.
Ecu is wired up, new fuse box and relays set.
I only need to source some suitable ballast resistors for the injectors, finish wiring connection for this.
Also need to get a power distribution post to connect the stock power feeds aswell as the starter cable to the battery etc. Ive refitted yhe battery tray, and will use a small drycell battery like what i used in my stockcar and rallycar.
Ive even mounted the hard fuel line and return. Fuel pump will now mount under the car without a surge tank because i wont have time to make a "firewall" for the boot area.
Bled up the clutch today, then noticed the fork was sitting in the wrong spot on the throw out bearing.
so pulled the box, found the metal retaining clip was bent.
smashed it back and reinstalled the box, now it sits great. Funny that..
not much left to do on it, probably a days work.
Couple of vac lines, finalise a bit of wiring, sort some radiator hoses/outlets etc. refit carpets and modify the console, fit the lower shifter boot.
and find a suitable pod filter.
  • Like 9
