SOHC Posted June 3, 2020 Author Posted June 3, 2020 I am going to order a new set of Turfmaster tires tomorrow and a new inner tubeĀ 2 Quote
Muncie Posted June 3, 2020 Posted June 3, 2020 Hey protip contact glue your tyre to the rim, not even joking its the only way i can keep them alive on my scooter. 1 Quote
SOHC Posted June 3, 2020 Author Posted June 3, 2020 Just now, Muncie said: Hey protip contact glue your tyre to the rim, not even joking its the only way i can keep them alive on my scooter. Thatās not a bad idea, thanks Quote
SOHC Posted June 3, 2020 Author Posted June 3, 2020 to put air in the tire I must remove it from the bike and remove brake disk, I will make a an attachment for the compressor at some stage. These tires stink, they have been in my shed for like 3 years and they still stink, every time I open the door I get hit with a blast of stinky tires. 1 Quote
SOHC Posted June 4, 2020 Author Posted June 4, 2020 Have to cut slot for the chain a tad longer, if anyone wants the 4" tires they can have them Quote
SOHC Posted June 4, 2020 Author Posted June 4, 2020 The new tires wonāt need glueing on, they are not lose on the rims like the old onesĀ Quote
SOHC Posted June 5, 2020 Author Posted June 5, 2020 Anyone want the 4" LAN YU road tires? they are still very good or they might go in the bin. I need to make a new bush for the steering head, alloy one has flogged out, I hope its dry tommrow, going to take this out on the road.Ā Quote
Muncie Posted June 5, 2020 Posted June 5, 2020 Be keen on spareĀ tyre for sons scooter thing. Where abouts are you? Quote
SOHC Posted June 6, 2020 Author Posted June 6, 2020 Woh all 4 wheel bearings fucked out, front one on one side fell apart and 1 Quote
SOHC Posted June 6, 2020 Author Posted June 6, 2020 Ā Ā Ordered x4 rim halves witch look like they have a better wheel bearing, the other rims have a tiny thing witch is pressed in from the inside and one good pothole was enough to make it totally fall apart. Quote
SOHC Posted June 6, 2020 Author Posted June 6, 2020 Also got this on order, sometimes when I crack the throttle the engine stalls or makes a puff of back smoke Quote
SOHC Posted November 19, 2020 Author Posted November 19, 2020 Ended up fitting new front wheel bearings, back ones need doing at some stage, the replacement Ā Chinese bearings are a little less shitty than the ones in the wheels, I packed them with molly grease as anything you put that shitĀ in lasts 10 times as long. Put the carb rebuild kit in and the carb was leaking out the main jet so I put the old one back in, I found to set the pilot mixture on aĀ Tecumseh carb you bring the screw out till you hit max RPM then set the idol stop adjuster to the desired idol, then set the main till the engine is sweet. brake cable snapped and pull start cord broke, got a new cord and found the mesh for the air intakeĀ is cutting into it from factory. I will go to my old work and make a new cable. 2 Quote
SOHC Posted May 11, 2023 Author Posted May 11, 2023 Got this old gokart, frame was cracked in about 6 places on that one tube and had meany layers of 1/4" plate brazed on, had to use the plasma cutter to blow out all the layers of steel. Quote
SOHC Posted May 11, 2023 Author Posted May 11, 2023 Got a honda GX200 and a torque converter to fit, it had a China 110cc CT style engine when I got it but it wasn't mounted very well 6 Quote
