Sambo Posted September 24, 2017 Author Share Posted September 24, 2017 Made a massive difference! Old one with a hole. Also this: Starting swapping to a terrano front. Painted the slam panel black, then realised that the Navara corner lights don't fit over the Terrano grille, so I've got some proper ones on the way. Still rolling the terrano front with the corner lights looking wack as fuck. Quote Link to comment Share on other sites More sharing options...
Sambo Posted May 30, 2018 Author Share Posted May 30, 2018 I'm pretty attached to this thing, but I'm fucking sick of having to continually fix things that were fucked up by the previous owner. So I'm getting another one. 3 Quote Link to comment Share on other sites More sharing options...
scooters Posted May 30, 2018 Share Posted May 30, 2018 Good work! Quote Link to comment Share on other sites More sharing options...
Sambo Posted September 17, 2018 Author Share Posted September 17, 2018 So I bought another one which was meant to be good and tidy, then I was just going to swap the trays over. Unfortunately it's got rot all along the top of the screen, and in the places I've already fixed it in the other ute, so I'm swapping the drivelines instead. Spent a couple of days last week swapping them over, now the good motor out of the new ute is in the old ute, and is running weird. It goes great with the electronic dissy, but ran really hot yesterday, then really cold today. I put a new thermostat in, so may that's a bit suss? 2 Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 17, 2018 Share Posted September 17, 2018 Radiator leaking or cap wrong? Fuck I wish mine was a king-cab. Quote Link to comment Share on other sites More sharing options...
Sambo Posted September 17, 2018 Author Share Posted September 17, 2018 I suppose that's an easy place to start! It didn't do this when it was in the other car though, the only changes to the cooling system are the thermostat and a possible bad job bleeding the system. I even took the radiator etc from the other one. Kingcab is the best, just sucks that they weren't available with anything other than the 2wd Z24. Maybe I should keep the flatdeck one and swap it onto a TD27 4wd chassis /dreams 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 18, 2018 Share Posted September 18, 2018 Definitely give it a good bleed then. First port of call. Does it have a bleed nut on the manifold? The VG30 in mine is super easy to bleed because of it. The other thing it could be is the gauge or sender. Mine started playing up literally days before I went on holiday but I'm pretty certain that's all mine is. 1 Quote Link to comment Share on other sites More sharing options...
Sambo Posted October 21, 2018 Author Share Posted October 21, 2018 So yeah, I still haven't done the cooling system. Friday was the last day of classes at uni for the year, and still have exams coming up, but hoping to find some time for it soon. I did track down an annoying rattle to a loose exhaust mount (steel to steel hard mount). Rejetted a weber 32/36 I got off a forum member quite a while ago, the first carb I've jetted, so that was fun. It was all going well until I noticed that someone had disabled the accelerator pump. Bought a new one from Ebay, and it's now probably totally lost in the Italian postal system. cocknballs.jpg I've also found a guy who has Z20e efi gear and a Z22 head to suit the inlet ports, so hopefully at some point the carb will become redundant. Z24ET ahoy. 3 Quote Link to comment Share on other sites More sharing options...
Sambo Posted October 31, 2018 Author Share Posted October 31, 2018 Today: This silly bitch lovely lady decided to move out of her stationary lane into my moving one and poked her wheel into my door and all the way down the side. Then she got out out and asked if she took her car to the panelbeater today when I'd be able to pay her back. Turns out she has no insurance, luckily this is the first car I've ever had full insurance on. Most of the damage is in the shaded part of the picture, but it has gouged every panel behind the guard. 1 2 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted October 31, 2018 Share Posted October 31, 2018 Disabled the accelerator pump? If that's the carb you hot off me it was in perfect working order when it came off my Datto? 1 Quote Link to comment Share on other sites More sharing options...
Sambo Posted October 31, 2018 Author Share Posted October 31, 2018 It may not be disabled, but it doesn't look like this anymore Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted October 31, 2018 Share Posted October 31, 2018 Is that the power valve actuator? Quote Link to comment Share on other sites More sharing options...
Sambo Posted October 31, 2018 Author Share Posted October 31, 2018 In all honesty I'm not too sure, it was just labeled accelerator pump on the diagrams I've been looking at. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted November 1, 2018 Share Posted November 1, 2018 Odd. TBH I retired that carb a long time ago. I'm 100% sure the accelerator pump would have been working though. Although it did used to blip a tiny bit when I dumped the secondary. (Kind of like how a rotary does when the secondaries are manualised) I got it in my head it wasnt big enough for my set up. (Which was the only reason I swapped it out for a 2bbl Holley) It ran the exact same 1/4 time, and same trap speed with both carbs. But the holley used shitloads less gas. Making that manual choke set up and rebushing the throttle shaft was a fuck around. Especially since with it mounted on the supercharger it never even needed any choke. Quote Link to comment Share on other sites More sharing options...
Sambo Posted November 2, 2018 Author Share Posted November 2, 2018 I'm quite impressed with the choke setup tbh, and the rest of the carb is super tidy. What kind of datto engine was it on again? I wonder if you got away with it because it was running jets that were only like 1 or 2 sizes down from what I'm using on a 2.4L Z24. 1 Quote Link to comment Share on other sites More sharing options...
Sambo Posted November 2, 2018 Author Share Posted November 2, 2018 I got a bit carried away yesterday and bought these. A set of 5 in 16x8. They're made in Japan, but the only maker's mark I can see is "4wd Engineering Service". They need a tidy up, but once I sell the tyres they should be free. Also, free plug for Youi insurance. 1 hour after submitting a claim form the car was booked to be assessed. My excess was also waived without needing to confirm fault with the other party or anything else. Bloody impressed for what's meant to be cut price insurance. Edit: this is the tidiest one. 2 Quote Link to comment Share on other sites More sharing options...
kyteler Posted November 2, 2018 Share Posted November 2, 2018 They'll look slick with some small tyres. 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted November 2, 2018 Share Posted November 2, 2018 4 Quote Link to comment Share on other sites More sharing options...
Sambo Posted November 2, 2018 Author Share Posted November 2, 2018 Damn, those are nice! I've been chatting with the joka who owns this (and should be dropping by the forums at some point). Got a wild Z20et build bored out to take z24 pistons etc etc. 3 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted November 12, 2018 Share Posted November 12, 2018 On 02/11/2018 at 14:08, Sambo said: I'm quite impressed with the choke setup tbh, and the rest of the carb is super tidy. What kind of datto engine was it on again? I wonder if you got away with it because it was running jets that were only like 1 or 2 sizes down from what I'm using on a 2.4L Z24. It was on an A15 which was being fed by an S/C14 supercharger. Driven at 1:1. So pulling the same volume of Air at wot (more or less) as a 2.8 litre engine. Quote Link to comment Share on other sites More sharing options...
