yetchh Posted December 13, 2016 Share Posted December 13, 2016 Could anyone tell me what the proper can timing marks are on a 2001 Mazda bj5 vvt? seem to get conflicting info of the net, from what I know I point I and E on the respective camshafts at each other at tdc correct? or is it one of the other three marks on the sprocket.. Pic for pics sake.. Thanks for any info.. Quote Link to comment Share on other sites More sharing options...
yetchh Posted December 14, 2016 Author Share Posted December 14, 2016 Anyone? Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 14, 2016 Share Posted December 14, 2016 BJ5 as in familia? Is it a BP engine? I think those I and E marks line up with the diagonal lines on the backing plate, such as... Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 14, 2016 Share Posted December 14, 2016 Better example Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 14, 2016 Share Posted December 14, 2016 Or put the crank pully at TDC and see what lines up at the cams. Quote Link to comment Share on other sites More sharing options...
yetchh Posted December 14, 2016 Author Share Posted December 14, 2016 Nah its a bj (snigger) 1.6, bj5w.. it's already been moved so I don't have a datum.. Mate got a bhg and did the gasket himself but it won't start, sounds like it's to far advanced or 180 deg out.. but he didn't line the cams up with tdc etc he just marked the belt and cams and put it back together like that.. I I told him he needs to confirm the timing marks but the net gives me three different options for timing.. Quote Link to comment Share on other sites More sharing options...
Valiant Posted December 14, 2016 Share Posted December 14, 2016 TDC is marked on the crank. I can't remember where but the key way will point straight up when it's lining up. Both sprockets have E and I line up with the flat face of the head from memory. Inside or outside it doesn't matter. I can't remember if the sprockets are interchangeable on these some of them have both E and I marked on them. They line up with the locating dowels. Make sure the Exhaust cam is lined up to the E locator on the cam sprocket and vice versa for the intake. if in doubt get it to rock on 4 to get you in the ball park. Quote Link to comment Share on other sites More sharing options...
yetchh Posted December 14, 2016 Author Share Posted December 14, 2016 Ok bro cheers.. Quote Link to comment Share on other sites More sharing options...
yetchh Posted December 14, 2016 Author Share Posted December 14, 2016 BJ5 as in familia? Is it a BP engine? I think those I and E marks line up with the diagonal lines on the backing plate, such as... Thanks for your help also bro.. Quote Link to comment Share on other sites More sharing options...
Valiant Posted December 14, 2016 Share Posted December 14, 2016 Oh yeah the cam locating pins will be on top when the cams are in the right place too. You can see it on the exhaust cam of All Torque's pic. Quote Link to comment Share on other sites More sharing options...
yetchh Posted December 14, 2016 Author Share Posted December 14, 2016 His pic is different mine tho, you can't actually see any marks on the other sprocket because of the vvt shit except for these indents on the sprocket edge.. Like this (those tags are all you can see on the inlet can) Or like this? Quote Link to comment Share on other sites More sharing options...
Valiant Posted December 14, 2016 Share Posted December 14, 2016 I can't remember now, it's been a few years. Get it to rock on 4 and work it out from there. Quote Link to comment Share on other sites More sharing options...
yetchh Posted December 14, 2016 Author Share Posted December 14, 2016 Ok bro cheers.. this is what I mean by conflicting/confounding info.. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted December 14, 2016 Share Posted December 14, 2016 Generally. When cams are at tdc the inlet and outlet cams on number 4 should be facing away from each other. Anyway remind me tomorrow and will see what auto data has to say. But if you can see the cam dowl on the non vvt gear is at the top, and the cam gear happens to have a mark that matches something, then use that mark as a reference to figure out where the vvt cam goes? 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted December 14, 2016 Share Posted December 14, 2016 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted December 14, 2016 Share Posted December 14, 2016 Check free length of tensioner spring is 61,8 mm14. Replace if necessary. Fit tensioner spring 14.Note: Rubber sleeve on spring should point away from tensioner pulley. Ensure timing marks on camshaft sprockets aligned with cylinder head upper face 9 & 10. Ensure crankshaft timing marks aligned 15. Fit timing belt in following order: Crankshaft sprocket. Guide pulley. Exhaust camshaft sprocket. Inlet camshaft sprocket. Tensioner pulley. Ensure belt is taut between sprockets on non-tensioned side.Note: Observe direction of rotation marks. Slacken tensioner bolt 13. Allow tensioner to operate. Fit crankshaft pulley boss 12. Fit crankshaft sprocket bolt 8. Turn crankshaft slowly 1 5/6 turns clockwise until crankshaft sprocket mark aligned with tension setting mark 16. Tighten tensioner bolt 13. Tightening torque: 38 - 51 Nm . Turn crankshaft slowly 2 1/6 turns clockwise. Ensure crankshaft pulley boss locating pin at 12 o'clock position 11. Ensure timing marks on camshaft sprockets aligned 9 & 10. Apply a load of 10 kg to belt at 17. Belt should deflect 6,0 - 7,5 mm . If not: Repeat tensioning procedure. Install components in reverse order of removal. Tighten crankshaft bolt 8. Tightening torque: 157 - 166 Nm . Tighten crankshaft bolts 1. Tightening torque: 12 - 17 Nm . Fit crankshaft position (CKP) sensor. Ensure crankshaft position (CKP) sensor air gap is 0,5 - 1,5 mm . I havnt read anything off that Just that info is for a BJ chassis with a 1.6 (ZM motor) 1 Quote Link to comment Share on other sites More sharing options...
yetchh Posted December 17, 2016 Author Share Posted December 17, 2016 Had one and two plug leads round the wrong way.. amateur mistake. Thanks for all the input.. 5 Quote Link to comment Share on other sites More sharing options...
