Tender Raisin Posted October 27, 2016 Share Posted October 27, 2016 I have purchased some modified and crack tested adjustable front struts. All the paperwork is there from the crack test, but at a closer look when i received everything, i realized the paperwork has a picture of the base of the strut with the sticker on it for identification purposes.(pic below white sticker) Now upon receiving the strut i have noticed the sticker has been painted over.(pic below grey is primer black top coat) I tried to slowly scrape a corner to see if i could have any success but thought i would see if anyone on here might no of some wizardry that could help me, before i ruin it and have to take them to get re-crack tested. Thanks Mike Quote Link to comment Share on other sites More sharing options...
chees- Posted October 27, 2016 Share Posted October 27, 2016 Unsure how to get the paint off but why would you need to re crack test them? From the looks of it thats a bc sticker for s13 struts, and because they are cut up and welded to the hubs its totally irrelevant now. Quote Link to comment Share on other sites More sharing options...
Tender Raisin Posted October 27, 2016 Author Share Posted October 27, 2016 The form from the crack testers states that the welds on the "components with the serial number (insert serial number)" were crack tested. I am guessing that without the serial number being visible on the casing now that they can not be verified as the exact components that were tested when going for cert. May need to add to cert questions thread to get this confirmed. 1 Quote Link to comment Share on other sites More sharing options...
chees- Posted October 27, 2016 Share Posted October 27, 2016 The form from the crack testers states that the welds on the "components with the serial number (insert serial number)" were crack tested. I am guessing that without the serial number being visible on the casing now that they can not be verified as the exact components that were tested when going for cert. May need to add to cert questions thread to get this confirmed. lol those aren't serial numbers, that's years and chassis with front left or front right. will be the exact same for all bc s13 shocks. i had no serial numbers on mine so im sure its not an issue. 1 Quote Link to comment Share on other sites More sharing options...
Tender Raisin Posted October 27, 2016 Author Share Posted October 27, 2016 And that ladies and gentlemen is what happens when you don't look closely enough at things... I didn't even click that 89 - 94 was years. Thanks Chees. still curious about the paint on sticker thing though in case. knowing my luck. Quote Link to comment Share on other sites More sharing options...
malarky Posted October 27, 2016 Share Posted October 27, 2016 It really depends on what the sticker and paint are made of, I personally would start with hot water, meths/turps, brake clean, if it still isn't budging, acetone, cum clean, thinners etc 3 Quote Link to comment Share on other sites More sharing options...
Muncie Posted October 27, 2016 Share Posted October 27, 2016 Wax and grease remover might be worth a crack ive used it on foil badges before took alot of rubbing after a while it softens the paint enough and will come away slow enough you can stop before damaging whats underneath. 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted October 31, 2016 Share Posted October 31, 2016 Brake fluid mate. most Kearns use shitty rattle can paint. Brake fluid will make it fry up like a P house. Quote Link to comment Share on other sites More sharing options...
tortron Posted October 31, 2016 Share Posted October 31, 2016 . Quote Link to comment Share on other sites More sharing options...
