starter motor / ignition issues
samsnz
my old corona running 3t wont turn over after the engine is hot. it starts first pop from cold but once the engine has been running the car wont turn over again.
i recently got the starter motor fully refit professionally but before long the problem began to occur again.
i have checked and cleaned all the terminals for the starter and wired a bigger earth for my battery in case the draw is higher now also but to no avail.
the dash lights dim when the key is turned so i think my ignition is working ok
i also have an after market immobilizer installed which seems to cut and restore the ignition ok but i cant be sure really.
i am leaning towards the immobilzer side of things as its the only variable i cant really be sure is working correctly.
any ideas?
ive re done the earth and im pretty positive (ha) its not the battery as its less than 3 months old. and its pretty big for the job it does. ill look into main power and switch/signal next. i just dont get why it turns over first pop when its dead cold, but as soon as the engine is warm starter says no.
