MTM Posted January 20, 2015 Share Posted January 20, 2015 Hey guys, Pretty much no next to nothing about cars and engines but I'm getting there slowly. My 4 speed gearbox leaks oil from time to time which I've noticed over the past 2 months on the driveway. I was getting quite a crunch in reverse but otherwise all other gears were fine. Now over past few days it could be my imagination but my gears just seem too easy to push around and everything feels a bit loose/smooth. Should I be concerned about a fried clutch or gearbox coming up? Thanks. Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 20, 2015 Share Posted January 20, 2015 It will be fine. You can see a clutch needing to be done a while before it needs to happen becuase you will first have to adjust it to its limit( unless previous owner already done that haha). I think lots of the gearboxes crunch into reverse but it will last years like that. Maybe you just learned to live with the gearbox better. That or something catastrophic might be waiting to happen haha Quote Link to comment Share on other sites More sharing options...
crustywhip Posted January 20, 2015 Share Posted January 20, 2015 Slap some banana skins in there. Quote Link to comment Share on other sites More sharing options...
MTM Posted January 20, 2015 Author Share Posted January 20, 2015 Haha sweet man, yea someone said they are pretty sturdy! I'll just keep rolling with it until something blows up or conbusts into flames. Quote Link to comment Share on other sites More sharing options...
pe-arce Posted January 20, 2015 Share Posted January 20, 2015 They're not too sturdy. I popped 1st gear in 2 of them before mine came off the road. It could feel loose if the gear stick is unscrewing itself.. Check that it's screwed in tight and has the tabs to stop it unscrewing. I had mine come off in my hand one day while I was nailing it down a passing lane. Was real unexpected. Quote Link to comment Share on other sites More sharing options...
downtrail Posted January 20, 2015 Share Posted January 20, 2015 Putting gearbox into 2nd before selecting reverse will slow the box enough to get into reverse without crunching. Quote Link to comment Share on other sites More sharing options...
igor Posted January 21, 2015 Share Posted January 21, 2015 My Falcon crunches when going into reverse but if I put it in 5th first then slam it straight back into reverse it's quiet as. I've forgotten what Escort shift pattern looks like but try what downtrail suggests. You'll know when the clutch is dying because it will start to slip like a wet bitch on steep hills and you will find that when you put your foot down the engine speed will increase but the vehicle speed will not. This may or may not be accompanied by the foul stench of burnt clutch lining. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted January 21, 2015 Share Posted January 21, 2015 Just wait 2-3 seconds after pushing clutch in before putting into reverse. It needs time for the gears to stop spinning before engagement as reverse is unsynchronized. If it doesn't want to go in then, let clutch out and repeat (the gear will have just stopped in the wrong spot). Quote Link to comment Share on other sites More sharing options...
downtrail Posted January 21, 2015 Share Posted January 21, 2015 ^^ thats what putting into gear does stops input shaft spinning either way its not a major worry you will never need to load reverse up to the max unless your into roll backs lol Quote Link to comment Share on other sites More sharing options...
