77magnum13hundy Posted October 2, 2014 Share Posted October 2, 2014 hey folks ive heard theres a trick to putting a window back into car with a peice of rope/string but didn't find any decent youtube videos or maybe i didnt look well enuff Any peeps here can chime in on how to do this... Cheers Rob Quote Link to comment Share on other sites More sharing options...
Ned Posted October 2, 2014 Share Posted October 2, 2014 the basic idea is that you wrap the string around the window, through the channel in the rubber. Feed the ends of the string into the car and lay the window on the window opening, as accurately as you can. You then start pulling the string so it pulls the rubber lip with it into the car. When you go all the way around, its pulled the window into the window hole. Havent done it myself, so there may be other neat tricks like grease the rubber, or not grease the rubber or whatever to make it slide better or what not Quote Link to comment Share on other sites More sharing options...
sheepers Posted October 2, 2014 Share Posted October 2, 2014 done it a few times. you need two people especially if you've never done it before and there are definitely youtube vids on it. ill have a look. Quote Link to comment Share on other sites More sharing options...
sheepers Posted October 2, 2014 Share Posted October 2, 2014 here are heaps of vids that should give you an idea. http://www.youtube.com/results?search_query=windscreen+instilation+rope 3 Quote Link to comment Share on other sites More sharing options...
The Bronze Posted October 2, 2014 Share Posted October 2, 2014 I've done it, once, on a front screen, need patience and definitely someone to help. Quote Link to comment Share on other sites More sharing options...
77magnum13hundy Posted October 3, 2014 Author Share Posted October 3, 2014 cheers will crack on with it and see how it goes... hopefully not the cracking part! awesome lads. Quote Link to comment Share on other sites More sharing options...
feathersword Posted October 3, 2014 Share Posted October 3, 2014 Having helped do this a couple times it definitely helps to have a couple sets of hands at least - take your time and you'll get it! Might take a couple tries! Quote Link to comment Share on other sites More sharing options...
sleeektoy Posted October 3, 2014 Share Posted October 3, 2014 use rope or thick string, nothing thin. The rubber will cut or tear if anything thin is used. Quote Link to comment Share on other sites More sharing options...
