feathersword Posted September 15, 2014 Share Posted September 15, 2014 As per titles, friend of mine having issues with his 93 auto Primera and trying to figure out what is wrong with it. Haven't been to look yet, but problems starting - so I'm thinking either battery is poked (or alternator meaning battery not charging), or starter motor - as first things to try and check. Plan is to take my car and try and jump it, if we are successful in doing that, that will likely mean starter motor is fine right? Thanking you in advance you fountain of knowledge! Quote Link to comment Share on other sites More sharing options...
punkoutnz Posted September 15, 2014 Share Posted September 15, 2014 If you jump it and it starts fine, then yes the starter motor is okay. If you jump it and it just clicks, or wont crank over at all, or cranks over very very slowly then I'd be looking at the starter motor. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 15, 2014 Share Posted September 15, 2014 Before replacing starter (if that's the problem) check all wires going to it first. I had an annoying problem when my little solenoid wire was loose. 1 Quote Link to comment Share on other sites More sharing options...
feathersword Posted September 15, 2014 Author Share Posted September 15, 2014 If you jump it and it starts fine, then yes the starter motor is okay. If you jump it and it just clicks, or wont crank over at all, or cranks over very very slowly then I'd be looking at the starter motor. That's what I thought, cheers for confirming Before replacing starter (if that's the problem) check all wires going to it first. I had an annoying problem when my little solenoid wire was loose. Will keep that in mind Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted September 15, 2014 Share Posted September 15, 2014 My brother's primera had the starter motor shit out. It's up under the manifold out of sight too. With the throttle wide open, I was able to get a long 1/2 inch extension down to the bump on the bellhousing when the starter motor sits. Giving it a good smack with a hammer would allow it to start. For a while, until the starter absolutely had to be replaced. Quote Link to comment Share on other sites More sharing options...
feathersword Posted September 15, 2014 Author Share Posted September 15, 2014 Managed to get car started, so not starter motor. Battery is apparently pretty new (within last year or so), so potentially alternator not charging it? Going to get battery checked so may come back for more help once that is done, cheers guys 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 15, 2014 Share Posted September 15, 2014 You got a multimeter? Or.. Easier.. Jump the car and leave it running with the lights on. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted September 15, 2014 Share Posted September 15, 2014 Fuel pumps in these are ultra shit. Quite easy to replace and cheap to buy. Had to do my brothers p10 recently. Fuckin nissans eh 1 Quote Link to comment Share on other sites More sharing options...
77magnum13hundy Posted September 15, 2014 Share Posted September 15, 2014 also when starting the car in P (park) does it make a difference if you try in N (neutral) at all? happens on the middys car and this solves it, the not starting part. Applicable to autos Oil pressure switch wire loose on some cars effects the starting as well. Quote Link to comment Share on other sites More sharing options...
