Sambo Posted August 6, 2014 Share Posted August 6, 2014 I went to replace the pinion seal on my AE85 yesterday and ran into something I wasn't expecting. There's a lot of play in the input to the diff, and every wiggle summons fresh drips of oil. I didn't think the pinion seal would cause play like that, it's several mm side to side. I had the LSD set up and installed into a new (second hand) nugget. Is there something else that's worn out? Or should I carry on and do the seal? Cheers. Quote Link to comment Share on other sites More sharing options...
downtrail Posted August 6, 2014 Share Posted August 6, 2014 Sounds like the backlash was not set up when installing the lsd Quote Link to comment Share on other sites More sharing options...
kpr Posted August 6, 2014 Share Posted August 6, 2014 sounds like pinion bearing is stuffed. or if they done anything with the pinion (don't have to touch it doing lsd install) hasn't been setup right. is the diff noisy ? Quote Link to comment Share on other sites More sharing options...
Sambo Posted August 6, 2014 Author Share Posted August 6, 2014 It's hard to say whether the diff is abnormally noisy, I've never driven another car with a 2way lsd. It is hella noisy though. Any way to quantify the noise? I'm not sure what was pulled apart for the install, I know that it's got new bearings and crush tubes. Thanks for the help so far! If it makes any difference, it's a t series and TRD diff, installed by Brendan Duncker. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted August 6, 2014 Share Posted August 6, 2014 I can't take this seriously with a profile pic like that.... All I imagine is 2 Quote Link to comment Share on other sites More sharing options...
kpr Posted August 6, 2014 Share Posted August 6, 2014 If its had new crush tube and bearings. the whole lot would have been apart. brendan is pretty onto it though, seem a bit weird that would be setup wrong. shouldn't be noisy at all. was it like that right from the start? my trd diffs there is no more noise than stock open. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 6, 2014 Share Posted August 6, 2014 pinion nut has come loose? Quote Link to comment Share on other sites More sharing options...
