Sidevalve: working out CR/how much to skim
tortron
Short of CC'ing the head, how can i figure this out
Lets assume everything is standard
4 cylinder
bore       :2.244in / 57mm
stroke     :3.543in / 90mm
capacity  : 56.04 cu.in / 918.636cc
compression ratio : 6.7:1
Headgasket: 0.0433in/1.1mm
will have to pop a vernier gauge down the spark plug hole to figure out piston heights
aiming for 7.5ish as the new ratio
Obviously the issue is the volume of the area above the valves, the area above the piston is mostly flat
On my briggs and stratton i skimmed as much as i could without the valves hitting the head. Doesnt detonate on 91, but i had planned on moving to methanol so that was never going to be the problem.
Not really relavant but theres my 10c
Ricardo combustion chamber
I have tried putting the plug over the piston on a side valve motor that had a bung for seting the timing, it ran like a bag of shit.
sounds about right.
Should put some Singh grooves in there too for max turbulence
ok gents, no one on here will want to know, but the head combustion chamber is 32cc per cylinder
also approx volume given by the headgasket is 5.4cc
deck height is 0.05in/1.27mm
all these measurements give me a compression ratio of 6.65 which is pretty spot on
Turns out i want to lose about 5cc per cylinder chamber (throw out the headgasket i hear you say)
now to figure out what that means in terms of my oddly shaped sidevalve head volume
lets assume the area is another rectangle approx 52*62mm
depth is around 10mm (deeper as you get towards the piston, and then slants up )
this gives 32cc
so in order to get 27cc i want to mill off 1.5mm, or about 0.06"
which doesnt sound to crazy does it
