NelsonEX Posted November 25, 2013 Share Posted November 25, 2013 Hi there,I own a gx71 toyota cresta (Super Lucent, Exceed 24V DOHC) witch come factory automatic and has been later converted to manual using a w55 gearbox.My question is what diff will this be running? It revs out at around 3750 at 100km/h so im guessing it still has the automatic diff in it.I cant find any information on the diff itself only a very faint stamp on the bottom of it that seems to resemble a 'T' but it has IRS and as far as I know T series diffs only come setup for a solid rear end?Im looking to swap this old diff out for something LSD so any suggestion of what might fit would also be good. Cheers Scott Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted November 25, 2013 Share Posted November 25, 2013 The build plate on the firewall has a diff code on it. Post that up. Quote Link to comment Share on other sites More sharing options...
beachlander Posted November 25, 2013 Share Posted November 25, 2013 Have a look on the build plate in your engine bay. Should have what diff you are running on it. Edit: Beaten Quote Link to comment Share on other sites More sharing options...
ANT Posted November 25, 2013 Share Posted November 25, 2013 Will most likely be F series 7.5" IRS. Factory turbo cresta's have the bigger 8" diff'sThe poverty spec x chassis sometimes came with Dumb T series IRS.Basicly look for one of these in the engine bay:And where it says axle thats where it will say "T or F"Edit: Also, Dont fuck the car. dont roll the rear guards with pipe or be a general knobcheese with it.. its a very rare car in nz.. 1 Quote Link to comment Share on other sites More sharing options...
NelsonEX Posted November 25, 2013 Author Share Posted November 25, 2013 Mate this cresta in my pride and joy factory 150k km's immaculate shes not getting molested at all! Cheers everyone I did look for the build plate tho ill take a second look now Quote Link to comment Share on other sites More sharing options...
NelsonEX Posted November 25, 2013 Author Share Posted November 25, 2013 F252 so from what I hear altezza lsd diff head's bolt into the crestas F series housing? Hers a couple of pics of the girl Quote Link to comment Share on other sites More sharing options...
ryanfels Posted November 25, 2013 Share Posted November 25, 2013 The torsen centre will bolt into the head of your car, not the whole altezza head Quote Link to comment Share on other sites More sharing options...
NelsonEX Posted November 25, 2013 Author Share Posted November 25, 2013 The torsen centre will bolt into the head of your car, not the whole altezza head Sweet as thanks Quote Link to comment Share on other sites More sharing options...
NelsonEX Posted November 25, 2013 Author Share Posted November 25, 2013 The torsen centre will bolt into the head of your car, not the whole altezza head Will any altezza lsd torsen center fit or only a specific model? Cheers Quote Link to comment Share on other sites More sharing options...
ANT Posted November 25, 2013 Share Posted November 25, 2013 The altezza diff is junk. Not worth it. Will 1 wheel as soon as you try do anything exciting in it. 1 Quote Link to comment Share on other sites More sharing options...
NelsonEX Posted November 25, 2013 Author Share Posted November 25, 2013 The altezza diff is junk. Not worth it. Will 1 wheel as soon as you try do anything exciting in it. Ill try sort some shims to go with it, I dont really feel like forking out $800 for a trd one :/ Quote Link to comment Share on other sites More sharing options...
ryanfels Posted November 25, 2013 Share Posted November 25, 2013 Ill try sort some shims to go with it, I dont really feel like forking out $800 for a trd one :/ Im pretty sure you cant shim a torsen. Torsens are great if your just planing on doing grip work. If you plan on drifting it for more than 3secs, they like to start single spinning Quote Link to comment Share on other sites More sharing options...
ANT Posted November 26, 2013 Share Posted November 26, 2013 Cant shim. What do you want it for? It will be fine to drive with, just once you want to spin both wheels, it won't. Edit: There was a trd on UpGarage for 40k yen last week.. Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted November 26, 2013 Share Posted November 26, 2013 was this on tardme a little while back on Shakotans? Quote Link to comment Share on other sites More sharing options...
ANT Posted November 26, 2013 Share Posted November 26, 2013 YA. It still has rota's on it by the looks. Quote Link to comment Share on other sites More sharing options...
NelsonEX Posted November 26, 2013 Author Share Posted November 26, 2013 Yes it was, yup its still on the rota's.. working on a few other bits and pieces before i fork out for some ssr mk3's.. Hmmm might invest on a trd upgrade then is there any other options? Quote Link to comment Share on other sites More sharing options...
ANT Posted November 26, 2013 Share Posted November 26, 2013 Heaps of options. All will cost you about a grand. possibly a bit more depending on what brand you go for. Quote Link to comment Share on other sites More sharing options...
