hulse12 Posted September 12, 2013 Share Posted September 12, 2013 Just had my diff head rebuilt.. Put it in, new oils, got car on ground nd went to turn it to move it over in my shed nd it started making a quiet ticking noise.. Didn't do it before I'm pretty sure but yeah read abit online saying lsds tick but just wana be sure. Let me know what you think?? Quote Link to comment Share on other sites More sharing options...
Truenotch Posted September 13, 2013 Share Posted September 13, 2013 Does it only do it when you're turning? With TRD LSD's they used to say "if it's not noisey, it's not working". Quote Link to comment Share on other sites More sharing options...
kpr Posted September 13, 2013 Share Posted September 13, 2013 ^ this. they can make a bit of noise. but shouldn't in a straight line. if it does, it isn't a problem with the lsd itself. unless you have different size wheels on or something silly Quote Link to comment Share on other sites More sharing options...
hulse12 Posted September 13, 2013 Author Share Posted September 13, 2013 Only while turning corners, never did before I had diff rebuilt? But yeah.. Quote Link to comment Share on other sites More sharing options...
beachlander Posted September 13, 2013 Share Posted September 13, 2013 Is it a standard LSD or aftermarket? Quote Link to comment Share on other sites More sharing options...
kpr Posted September 13, 2013 Share Posted September 13, 2013 preload on clutch packs is probably set tighter. so need more effort to slip the clutch packs. when they do slip, that will be your clunk. before would have been old and sloppy Quote Link to comment Share on other sites More sharing options...
hulse12 Posted September 13, 2013 Author Share Posted September 13, 2013 Standard B1600 LSD I'm pretty sure, could have a couple more shims in there than from factory? Not 100% sure as I havnt seen another one stripped down. Sweet, thanks kpr. Just don't really wana have to rebuild it again haha and cbf taking it out.. Cheers! Quote Link to comment Share on other sites More sharing options...
shandawg Posted September 13, 2013 Share Posted September 13, 2013 I'm sure you did, but did you use proper LSD oil? 1 Quote Link to comment Share on other sites More sharing options...
hulse12 Posted September 13, 2013 Author Share Posted September 13, 2013 Sure I did what? Yup new limited slip oil in it Quote Link to comment Share on other sites More sharing options...
