Hachi-ichi Posted June 17, 2013 Share Posted June 17, 2013 So I am in the cert process for my GX81. It's interesting to say the least, All I need doing to get it done is bring down the rear camber a wee bit. My limit is -1.2˚ Currently I am running Rear Right -1.3˚ Rear Left -2.12˚ So I need to get that to -1.2˚ at most to pass alignment wise. Along with that I need to do the rear Hub arm bushes, those alone apparently costing 560 bucs to do. Apart from camber arms and offset bushes, are there ANY other methods of deleting camber? At the moment its just the price of getting the Hub arm bushes done that is annoying me, 560 for 2 bushes. Is the cheapest solution just to raise it for cert, get it certed at the height that fixes the camber, and then back down? I don't think the law likes low cars at all ha. Any response/help is awesome. Cheers, Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted June 17, 2013 Share Posted June 17, 2013 yeah thats the same problem with gx71's aswell. we are working on a camber adjustment solution/kit just have to find some good bolts to use for it. you cut an old mount off and weld on this mount in its place and it give you a good rand of adjustable camber hopefully!! the only other way is raise the car for a cert and drop it after. pretty shitty really. Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted June 17, 2013 Author Share Posted June 17, 2013 I may just have to cop it, and raise the thing somewhat for cert, deleting camber but inducing poke on my SSRs haha. Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted June 17, 2013 Share Posted June 17, 2013 2 birds, one stone? saves doing the bushes when you can just use these http://www.xcessivemanufacturing.com/ONLINESTORE.html?cid=61&step=4&pid=257 Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted June 17, 2013 Share Posted June 17, 2013 plus it helps get rid of the sloppy rear end these have. if you care about that, I'd get the solid subframe and diff bushings too. Quote Link to comment Share on other sites More sharing options...
beachlander Posted June 17, 2013 Share Posted June 17, 2013 Yea ill be getting some xm stuff soon, was going to go serial nine but not anymore. 1 Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted June 17, 2013 Share Posted June 17, 2013 damnit! anyone know if anyone sells a kit like that for gx71's!!! Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted June 18, 2013 Author Share Posted June 18, 2013 2 birds, one stone? saves doing the bushes when you can just use these http://www.xcessivemanufacturing.com/ONLINESTORE.html?cid=61&step=4&pid=257 I um already got exited over those. Thing is, the Bushes I need replacing are attached to the Hub. ( on the U shapped end of the Arms), I was all like "sweet sorted, arms are sweet, they will do bushes at the same time" nup. The Bushes I need replaced are those annoying ones built into the Hub itself. Cheers though. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted June 18, 2013 Share Posted June 18, 2013 damnit! anyone know if anyone sells a kit like that for gx71's!!! X7s and X8s have completely different rear ends Quote Link to comment Share on other sites More sharing options...
ryanfels Posted June 18, 2013 Share Posted June 18, 2013 2 birds, one stone? saves doing the bushes when you can just use these http://www.xcessivemanufacturing.com/ONLINESTORE.html?cid=61&step=4&pid=257 Just double check with your cert man that the welds and the rose joints are ok. Some rose joints taper down at the threaded end and wont pass! Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted June 18, 2013 Author Share Posted June 18, 2013 http://www.xcessivemanufacturing.com/ONLINESTORE.html?cid=61&step=4&pid=265 Those are what I need to sort the bushes anyway. Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted June 18, 2013 Author Share Posted June 18, 2013 I went to go purchase the pillowball lower bushes, USD 169 for shipping. I flicked them an email explaining it doesn't cost that much to send what is essentially an envelope of parts to NZ. Can't wait to here their reply. Quote Link to comment Share on other sites More sharing options...
durty Posted June 18, 2013 Share Posted June 18, 2013 set up a youshop account and get them shipped that way, will be like $30 1 Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted June 18, 2013 Author Share Posted June 18, 2013 Genius. Quote Link to comment Share on other sites More sharing options...
