sheepers Posted February 8, 2013 Share Posted February 8, 2013 ive got an MR2 electric P/S pump for the crown and im wondering how best to trigger it on and off. from what im told the MR2 has a pressure sensor in the rack that triggers the pump as soon as you turn the wheel. my steering box has none of this trickery so im going to need to do it another way. how have you seen it done? there are a few ways but if you know of a good way let me know. thanks!!! sheepers. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 8, 2013 Share Posted February 8, 2013 Fuckin phone... Il try again. Pretty sure the mr2s steering assistance is dependant on vehicle speed and I think there are also sensors to tell the car when the steering wheel is being moved. You should def fit some kind of pump speed controller so that you can vary steering assistance from in the cab! And have it vary assistance based on vehicle speed too Ned could prob design you a thing to do it in 5 seconds Quote Link to comment Share on other sites More sharing options...
ta63-1uzze Posted February 8, 2013 Share Posted February 8, 2013 Yes they have a module that has uses an optical sensor input from the steering shaft (cabin side) this tells the ecu the steering angle ,also it uses a speed sensor of the gearbox so that at high speed you don’t have full power to the pump as it makes the steering to light. The pump has 3 possibly 4 power inputs ( i can’t remember as it’s been so long since i have played with one) you could just wire the pump to mid speed, so the pump is always on , key on power, this is not a problem and it is how most hot rod / stock car / modifiers run there pumps. If you have an output from the gearbox or even from an aftermarket ecu then you could potentially use the factory mr2 steering control module, just need to fit up the angle sensor I used one of these pumps on my old car it works well as a single speed pump. Quote Link to comment Share on other sites More sharing options...
ProZac Posted February 10, 2013 Share Posted February 10, 2013 Going the same route with my black Starion. Going to use a solid state relay, and setup a little box that feeds the relay a PWM signal, the duty cycle of which decreases with increasing speed (to decrease the assistance at higher speeds). Not sure what sort of frequency to drive the signal at, but that shouldn't be too hard to figure out. As an aside, doing the same thing with solid state relays, and your fuel pumps (but an increasing duty cycle instead of decreasing) is a great way to make them nice and quiet at idle . Quote Link to comment Share on other sites More sharing options...
