Seedy Al Posted January 21, 2013 Share Posted January 21, 2013 This car looks freaken sweet in the flesh good sir Quote Link to comment Share on other sites More sharing options...
BattleSnayke Posted January 21, 2013 Author Share Posted January 21, 2013 Cheers man, loved the van! Quote Link to comment Share on other sites More sharing options...
Bistro Posted January 21, 2013 Share Posted January 21, 2013 What you thinking of getting big fella? Quote Link to comment Share on other sites More sharing options...
BattleSnayke Posted January 21, 2013 Author Share Posted January 21, 2013 Something suitably big, a crown or Cressida or something similar Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted January 21, 2013 Share Posted January 21, 2013 What sort of $$$$ will the AE70 be going for? Quote Link to comment Share on other sites More sharing options...
BattleSnayke Posted January 21, 2013 Author Share Posted January 21, 2013 I chucked it up in for sale, open to offers and swaps etc but not too keen on selling the wheels. Hoping for around $6500 otherwise I'll just keep it. I don't really have a reason for selling it other than my mate just got a 1UZ Cressida and I've fallen in love. Quote Link to comment Share on other sites More sharing options...
Guest Seedy Al Posted April 2, 2013 Share Posted April 2, 2013 awesome swap mate! Should make for a sweet vehicle once its done, looks and Engine poke its got everything Quote Link to comment Share on other sites More sharing options...
Guest ryanfels Posted April 2, 2013 Share Posted April 2, 2013 Why not covert to rack and pinion? Quote Link to comment Share on other sites More sharing options...
Guest Seedy Al Posted April 2, 2013 Share Posted April 2, 2013 Also what ECU are you running?? there is a Chap on here Nanarie (think i spelt his name wrong there) he has a ke30 running a running a silver top he converted his factory ECU to run Wasted Spark instead of Dissy, looks heaps tidier, so if you are using the factory ECU (tho I am guess it would have to be a black top one with those trumpets) then he could be the man to talk to. Quote Link to comment Share on other sites More sharing options...
Guest BattleSnayke Posted April 2, 2013 Share Posted April 2, 2013 Yeah have a blacktop ecu but I'm not 100% convinced that it's going to work, I was thinking that I'd have to fork out for a aftermarket ecu like a link. Quote Link to comment Share on other sites More sharing options...
Guest ryanfels Posted April 2, 2013 Share Posted April 2, 2013 Why wont it work? Quote Link to comment Share on other sites More sharing options...
Guest BattleSnayke Posted April 2, 2013 Share Posted April 2, 2013 I don't have a reason to doubt it if someone else has done it, was just expecting it to be more difficult than it has been so far. First time do a engine swap so learning it all as I go. Quote Link to comment Share on other sites More sharing options...
Guest ryanfels Posted April 2, 2013 Share Posted April 2, 2013 A old mate of mine had trumpets on his silvertop just by using a blakctop loom and ecu. The only real difficult part with the 20v swap is the dizzy hitting the firewall and the waterlines can be tricky to make if you want to make them tidy and hidden Quote Link to comment Share on other sites More sharing options...
Guest BattleSnayke Posted April 2, 2013 Share Posted April 2, 2013 Do you know how he ran the silvertop itbs on a map sensor? I had read somewhere that the vac sensor on black tops is at a different point? Quote Link to comment Share on other sites More sharing options...
Guest Seedy Al Posted April 2, 2013 Share Posted April 2, 2013 usually the sensor should be a sperate item. just run vacum line to sensor, mount where ever you see fit. this is just speculation tho, as i have never played with silver slash black top stuff. but I assume they are all the same as any toyota Silver tops dont use a map sensor to start with, they use an AFM Quote Link to comment Share on other sites More sharing options...
Guest BattleSnayke Posted April 2, 2013 Share Posted April 2, 2013 I understood that silver top had a afm on the outside of the itbs and blacktop have vac on the inside of itbs. Quote Link to comment Share on other sites More sharing options...
Guest Seedy Al Posted April 2, 2013 Share Posted April 2, 2013 yeah that is pretty much true. but you can get vacuum from where on an engine after the throuttle plates in the ITB's As every vehicle need vacuum to operate boosted brakes etc. I'm pretty certian silver top ITB's have a vacuum balance pipe or some such in them, which is where you would be connecting your Vac pipe to the map sensor Quote Link to comment Share on other sites More sharing options...
Guest NicT Posted April 4, 2013 Share Posted April 4, 2013 Those relocation kits are good. They work exactly as intended. Are you getting it from Sam in australia? Quote Link to comment Share on other sites More sharing options...
Guest BattleSnayke Posted April 4, 2013 Share Posted April 4, 2013 SQ Engineering? Getting a few parts from them. It might cost a little more, but it makes it easy and tidy. Getting one of their coolant setups as well Quote Link to comment Share on other sites More sharing options...
ryanfels Posted May 28, 2013 Share Posted May 28, 2013 Keen to know more about these headers Quote Link to comment Share on other sites More sharing options...
