mk2 gt Posted December 6, 2012 Share Posted December 6, 2012 Hey guys i finally got my carb setup on to my 2-Tc, im not running a low fuel pressure reg so i think its over fueling it as they are meant to run at 3psi and its spitting the fuel out the front and vent holes at the top. I have also noticed a nice little squeak noise its making which is hard to tell in this video until the end when i shut it off. Any help would be hugely appreciated! http://www.youtube.com/watch?feature=player_embedded&v=qfxredUJ2s4 Quote Link to comment Share on other sites More sharing options...
7ESKY9 Posted December 6, 2012 Share Posted December 6, 2012 Yeah man get a fuel reg on it did all the same things with mine running to much psi. Set it at 3 psi and should be good as Quote Link to comment Share on other sites More sharing options...
mk2 gt Posted December 6, 2012 Author Share Posted December 6, 2012 awesome thats reassuring! cheers for the reply i will get it on asap and see how it goes Quote Link to comment Share on other sites More sharing options...
shaneo Posted December 6, 2012 Share Posted December 6, 2012 You need a low pressure high flow fuel pump. I got one from part master for $90 for my set up. Sounds to me like over fuel Quote Link to comment Share on other sites More sharing options...
Rookie Posted December 6, 2012 Share Posted December 6, 2012 Also it has an air leak. Quote Link to comment Share on other sites More sharing options...
mk2 gt Posted December 6, 2012 Author Share Posted December 6, 2012 The air leak is not going to be fun to find..... Quote Link to comment Share on other sites More sharing options...
peteretep Posted December 6, 2012 Share Posted December 6, 2012 a standard pump should flow enough fuel, if it is standard im surprised that the pressure is too much air leak shouldnt be too hard as you should be able to isolate each runner and test from there Quote Link to comment Share on other sites More sharing options...
mk2 gt Posted December 7, 2012 Author Share Posted December 7, 2012 i know its a easy fix but at this point and time i cant be bothered im tempted to just pay someone to do it for me, if you can recommend anyone please let me know Quote Link to comment Share on other sites More sharing options...
Rookie Posted December 7, 2012 Share Posted December 7, 2012 Good luck, carb people think bike carbs belong on bikes hahaha Quote Link to comment Share on other sites More sharing options...
mk2 gt Posted December 8, 2012 Author Share Posted December 8, 2012 Good luck, carb people think bike carbs belong on bikes hahaha haha yeah thats my thoughts to... cant really take it to either or as they will just look at me sideways Quote Link to comment Share on other sites More sharing options...
peteretep Posted December 8, 2012 Share Posted December 8, 2012 yeah its a shame, most mechanics seem to be real against it for no reason Quote Link to comment Share on other sites More sharing options...
shaneo Posted December 8, 2012 Share Posted December 8, 2012 lots of people get them but finding some one that can tune them is a different story Quote Link to comment Share on other sites More sharing options...
mk2 gt Posted December 9, 2012 Author Share Posted December 9, 2012 another question the fuel reg i have here doesn't have a fuel return line? do i need to run one of this carb setup with mechanical pump or will it be find without it? what have others done? Quote Link to comment Share on other sites More sharing options...
peteretep Posted December 9, 2012 Share Posted December 9, 2012 nah you dont need a return line if the regulator doesnt have a fitting for it Quote Link to comment Share on other sites More sharing options...
kicker Posted December 9, 2012 Share Posted December 9, 2012 Even when bike carbs are on a bike it's hard to find someone to tune them, most shops cbf'd Quote Link to comment Share on other sites More sharing options...
mk2 gt Posted December 10, 2012 Author Share Posted December 10, 2012 next step is to strip and clean everything Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 11, 2012 Share Posted December 11, 2012 a bike mechanic is your best bet, thats the only reason i like them. just dont go to an old guy they dont like it Quote Link to comment Share on other sites More sharing options...
mk2 gt Posted December 13, 2012 Author Share Posted December 13, 2012 cheers, i have ordered new float needles etc so ill replace them for piece of mind that should rectify the over fueling problem *touch wood* Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 13, 2012 Share Posted December 13, 2012 read up on balancing bike carbs, its real easy to to do and you don't need a fancy set of gauges you can use a length of clear pipe to make a cheap manometer. make sure you get your fuel pressure to 3psi and have the carbs balanced before you do any jetting changes Quote Link to comment Share on other sites More sharing options...
shaneo Posted December 14, 2012 Share Posted December 14, 2012 I have a carb balancer that I bought specially for the carbs makes life very easy with out one they will always be a problem. Once balanced they are magic and sound great. Pm if you need some help but balance before buying parts Quote Link to comment Share on other sites More sharing options...
