ProZac Posted November 14, 2012 Share Posted November 14, 2012 I'm putting together the order for the bits to fit the td05h to my Starion. The oil supply is baffling me a little... The turbo has an M12x1.25 thread, which seems fairly generic, and is nice and easy to get AN adaptors for. The supply from the oil filter housing has me a little stumped however. Ive circled the stock supply line in red in the picture below. Ideally I'd like to do away with the adaptor that's in place, and replace it with a -4AN adaptor, to match the turbo side. Can anyone tell me what the thread in the oil filter housing is here? (not the flare adaptor screwed in). It's tapered, if that helps. I really need to study up on threads other than nice simple metric ones! Quote Link to comment Share on other sites More sharing options...
Ogre Posted November 15, 2012 Share Posted November 15, 2012 You sure its not metric? looking at it i would guess at 1/4 BSP if its not metric. Quote Link to comment Share on other sites More sharing options...
ProZac Posted November 16, 2012 Author Share Posted November 16, 2012 Nah, definately not metric. I did some measuring and it looked close to the specs for 1/4 NPT, so I ordered an adaptor to -4AN... Was only like $4.50 if I'm wrong. Will try 3/8 BSP if so, cheers. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted November 16, 2012 Share Posted November 16, 2012 Automotive is usually NPT, so you should be on the money. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 16, 2012 Share Posted November 16, 2012 Measure the inner diameter and the thread pitch and a close up pic and post it here Quote Link to comment Share on other sites More sharing options...
ProZac Posted November 20, 2012 Author Share Posted November 20, 2012 Alas, not 1/4NPT, has one more thread per inch, so that's 19. I'll find a 1/4BSP apadtor and that'll be the go. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted November 22, 2012 Share Posted November 22, 2012 Looks like 1/8 BSP- I have a tap for that one. Not that it helps you. Quote Link to comment Share on other sites More sharing options...
ProZac Posted November 23, 2012 Author Share Posted November 23, 2012 Nah, definately 1/4BSP Tapered. No-one seems to do a nice alloy adaptor to -4AN, so I bought a steel -4an fitting, and will weld it to the original fitting . Quote Link to comment Share on other sites More sharing options...
Ogre Posted November 23, 2012 Share Posted November 23, 2012 BOOM!! Quote Link to comment Share on other sites More sharing options...
