1UZ powered Pajero
NVMPAJ
  • Replies 112
Power steering .....I hope Ive fixed , will do another loud road test tomorrow. I found jacking the car off the wheels and turning the steering from lock to lock ,then shutting down , caused a nice big bubble of air to escape from the reservoir .
Still to do:
Exhaust
Driveshaft loop
Oil leak from remote filter set-up
Move fuel pump (too loud where it is)
Stereo
Cert and WOF
Another test , power steering pump is abit noisey. Same with fuel pump. Idle is good ,as is oil pressure , water temp to (found dash and triple gauge water temp earth wasn't the best all good now tho.)
http://m.youtube.com/watch?feature=em-upload_owner&v=7jwKu06Cxso&desktop_uri=%2Fwatch%3Fv%3D7jwKu06Cxso%26feature%3Dem-upload_owner
Quietened the fuel pump down a bit with a better mounting kit. Also mounted the filter along side instead of the engine bay.  Sorry no pics , cos you cant see it. will put some sound deadening stuff in the back , then should be fine.
  • 5 weeks later...
Still pottering away, brakes were playing hard to get , turns out the vacuum pipe was the wrong way round ! The pedal has a bit of travel but they work. Have loaned a mig welder so wil try my hand at making the exhaust up .
https://m.youtube.com/watch?v=paBcp4Cif7Y&feature=em-upload_owner
Well a few jobs done , motor running a lot quieter now power-steer is much more quieter . Thin a wee bit of oil and it'll be fine . Fuel pressure and vacuum pressure gauges fitted . Still have an oil leak , will have to remove the oil filter adaptor and check everything out.
  • 6 months later...
