PowderJZX Posted July 2, 2012 Share Posted July 2, 2012 Hey guys One of my cylinder is weak! chances are its the compression but then again, there is spark but there's no smoke so it can't be it. I changed the leads, spark plugs, and cap and dist rotors and still nothing (made it an upgrade tho lol).. I'll have it compression tested if i couldn't find it. but my guess is, its the injectors.. well one of them. i put a new sparks in and took #2 out (the weak one) tried smelling it and there's no gasoline smell to it!.. I took it off the road for 2 months and now that i am driving it again, it just started happening. I'll swap injector 2 with injector 1 and see if it changes to #1 piston. and if its not, worst case is the bulb inside..might be corrodade. anyone know what the problem is? Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted July 2, 2012 Share Posted July 2, 2012 This was difficult to read. You mean a misfire yes? Yeah, try swapping injectors. How do you know its #2? Quote Link to comment Share on other sites More sharing options...
fuel Posted July 2, 2012 Share Posted July 2, 2012 compression test. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted July 2, 2012 Share Posted July 2, 2012 compression test. Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted July 2, 2012 Share Posted July 2, 2012 i have one also that is missing its not the plugs or leads but yeah i just run it on 91 and it seems to run better ill just drive it until i dies hahaa Quote Link to comment Share on other sites More sharing options...
al_feinted Posted July 4, 2012 Share Posted July 4, 2012 Hey man, i have spare 1GEU injectors if you need em let me know. Quote Link to comment Share on other sites More sharing options...
