BlownCorona Posted July 1, 2012 Author Share Posted July 1, 2012 hypotheticaly, im the most simple of terms, what would be required to convert to cdi? Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted July 1, 2012 Share Posted July 1, 2012 a cdi control box and a cleverly invent some form of pickup or steal stuff from another bike and make it fit Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 1, 2012 Author Share Posted July 1, 2012 sounds more expensive and alot more work than fitting a coil. i guess ill just slap on the factory parts and try at get it going. need to buy those said parts first though... Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 11, 2012 Author Share Posted July 11, 2012 Just dropped a fair amount of coin on this, should be back on the road very soon if all goes to plan! Quote Link to comment Share on other sites More sharing options...
AndyGal Posted July 12, 2012 Share Posted July 12, 2012 pictures! get it ready for bike night, this time next week! Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 12, 2012 Author Share Posted July 12, 2012 highly unlikely, but ill be going hard on it once the parts arrive, haven't ridden in far too long. purchased -new, slide, needle kit, spring, top hat. -used coil -engine sprocket so if im right. i have all the parts i need to put this thing back together and doort around with 8hp. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 21, 2012 Author Share Posted July 21, 2012 My new parts arived for this, Except instead of a slide needle set, i got sent a float needle set but i have plenty to get on with untill i really need the needle. should be able to get it sused with them this week. Im sufficiently confused because the coil i got sent only has one wire, when i was expecting 2 + the spark plug lead. as far as i can see, the points connect to earth, and the bolts on the coil will be earthed, where does the black wire from the coil go? to the battery? i really need to work it out for sure so i don't fry it, cause it was expensive :/ it looks like this, but is cream and made by denso (cant find any info with the part number though) Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted July 21, 2012 Share Posted July 21, 2012 thats a cdi coil. points coil has 2 wires, one to the 12v+ from the regulator the other goes to the points with the condenser/cap inline Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 21, 2012 Author Share Posted July 21, 2012 got this coil from econohonda, sent my carb so they could pull numbers off it and match up the parts.. its got a condenser attached to the frame. ill have to get a picture of the real one. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted July 21, 2012 Share Posted July 21, 2012 i know you can use a points coil for cdi systems but im not sure on the logistics of using a cdi coil on points (if possible at all) but you would likely have to isolate the coil and have the points and cap wired to the core (the bolt holes) if it worked im not sure how long the winding would last though Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted July 21, 2012 Share Posted July 21, 2012 oh wait a condenser attached to the frame of the coil? Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 21, 2012 Author Share Posted July 21, 2012 yes it is. ill take some quick photos and upload them Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 21, 2012 Author Share Posted July 21, 2012 Quote Link to comment Share on other sites More sharing options...
governorsam Posted July 21, 2012 Share Posted July 21, 2012 Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 21, 2012 Author Share Posted July 21, 2012 ^Thats what ive been staring at for the past month, the coil in that diagram has 2 wires i knew how to wire that style up. but now this curveball Quote Link to comment Share on other sites More sharing options...
governorsam Posted July 21, 2012 Share Posted July 21, 2012 they have sent you a c50 coil. c90's need the 2 wire type. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 21, 2012 Author Share Posted July 21, 2012 fucking hell Quote Link to comment Share on other sites More sharing options...
governorsam Posted July 21, 2012 Share Posted July 21, 2012 a ballast coil from a car will work in a pinch, just don't use the ballast.. c90's need a battery and a good charging system to run. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 21, 2012 Author Share Posted July 21, 2012 i have a battery ready, and i know how to build a rectifier for the ac charging system. so that should be fine for charging, ive deciphered the 1st wiring diagram you posted for my bike, but now this is the second supplier that has supplied be with a bullshit coil. how hard is this? no way this coil can be used? Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted July 21, 2012 Share Posted July 21, 2012 the points wire goes to the condenser job done Quote Link to comment Share on other sites More sharing options...
