be4ver Posted June 4, 2012 Share Posted June 4, 2012 discuss accordingly here Quote Link to comment Share on other sites More sharing options...
be4ver Posted June 4, 2012 Author Share Posted June 4, 2012 oh if anyone has a mint rear bumper or knows where to find one let me know! Quote Link to comment Share on other sites More sharing options...
brocky41 Posted June 4, 2012 Share Posted June 4, 2012 I knew of one, but was too slow getting to it and has since found the crushers - real gay cos it had good guards and bonnet. Ill keep an ear out for you though cos im after bits for my 240c wagon. Sweet looking car dude - you gotta love how lux and cruizy they are though Quote Link to comment Share on other sites More sharing options...
Snoozin Posted June 4, 2012 Share Posted June 4, 2012 Good score, I watched this on Trademe with interest Good to see it's a nice solid car, if you want part numbers on the bits I used to slam mine sing out. Quote Link to comment Share on other sites More sharing options...
be4ver Posted June 4, 2012 Author Share Posted June 4, 2012 I would like that very much! How low was yours? I wanna make as low as I can within the law Quote Link to comment Share on other sites More sharing options...
Snoozin Posted June 5, 2012 Share Posted June 5, 2012 Mine's relatively low, big tyres are holding it up but it was bang on 100mm to the crossmember when the springs were fresh, I imagine they've sagged a bit now. Rear is super simple 2" blocks and a 30mm reset of the springs so that's easy as. I had to cut my bumpstops down at both ends but unless you're a 260C trainspotter no one is going to know, plus it's still super squishy and sweet when it hits them over the really large bumps/undulation. Quote Link to comment Share on other sites More sharing options...
Snoozin Posted June 5, 2012 Share Posted June 5, 2012 There you go, it's a little lower now. Quote Link to comment Share on other sites More sharing options...
be4ver Posted June 5, 2012 Author Share Posted June 5, 2012 That's mint! Definitely give me those part numbers for what ya got in the front! Would e awesome cheers Quote Link to comment Share on other sites More sharing options...
brocky41 Posted June 11, 2012 Share Posted June 11, 2012 Hey dude as per answer datsun site - BNT - just ask them to look for 330 or 230 pretty sure they were the same Quote Link to comment Share on other sites More sharing options...
Snoozin Posted June 11, 2012 Share Posted June 11, 2012 KK has been through this as I understand. 230 ball joints have a smaller taper than 330 ones, so you'll run into the same issue as you did with the 720 ball joints. So your options are thus: - rebuild the 230 ball joints - get the tapers bored to suit the larger 330 ball joint - find some late 230 or 330 hubs/knuckles (or whatever they are... this kind of suspension is still foreign to me) and install, buy 330 ball joints and live happily ever after. But KK will be able to give you a definitive answer as he encountered the same issue with the 230 wagon, and no doubt given time I'll encounter the same problem with my one. Quote Link to comment Share on other sites More sharing options...
Llama Posted September 8, 2012 Share Posted September 8, 2012 On removing all the muck, I had the same problem with my kingpins, and found that Shower witch (shower cleaner stuff) works great and is cheap. I soaked a few rags in the cleaner, then let the kingpin soak in a bowl for a bit. Then came off easily with a wire brush. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 9, 2012 Share Posted September 9, 2012 KK has been through this as I understand.230 ball joints have a smaller taper than 330 ones, so you'll run into the same issue as you did with the 720 ball joints. So your options are thus: - rebuild the 230 ball joints - get the tapers bored to suit the larger 330 ball joint - find some late 230 or 330 hubs/knuckles (or whatever they are... this kind of suspension is still foreign to me) and install, buy 330 ball joints and live happily ever after. But KK will be able to give you a definitive answer as he encountered the same issue with the 230 wagon, and no doubt given time I'll encounter the same problem with my one. Sorry I have only just seen this now. I did option 2. Cost me $120 for an engineer to machine the tapers bigger. You can buy brand new 330 joints no problems.. Get the joints from Autolign or BnT and give the new joints and stub axles to an engineer - you will live happily ever after. Quote Link to comment Share on other sites More sharing options...
be4ver Posted September 9, 2012 Author Share Posted September 9, 2012 Oh all good man! I've actually already sent them off to get repaired, decided that the for the cost of new ball joints plus the cost of engineers time plus the cuntyness of pulling shit all apart, It would be far easier to just get the old ones repaired and bang straight back in. New off the shelf ones would have been better to fit I know but I'm sure these fixed ones will still out last the rest of the cars lifespan or my ownership of it at least. Happily ever after. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 9, 2012 Share Posted September 9, 2012 I would agree but it depends who is rebuilding the joints - if they are just injecting a polymer into the joint then they will last fuck all. If they are properly pulling the joints apart and remanufacturing the parts then it should be all good.. When I did it I could not be entirely sure whether the ones I was going to get rebuilt were going to be done properly or not so I went with the option I did. There is now one company that does a top job on them but the name escapes me - I think they are in Christchurch... (although they are expensive as all hell) Quote Link to comment Share on other sites More sharing options...
be4ver Posted September 10, 2012 Author Share Posted September 10, 2012 Yeah HBI in chch are doing them, Gunna be about 300 for both of them so hopefully they aren't just injecting shit into them! Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 10, 2012 Share Posted September 10, 2012 Just found this thread.. (looks like HBI are the buisness I was recalling) http://www.oldschool.co.nz/phpbb/viewto ... =2&t=34217 Quote Link to comment Share on other sites More sharing options...
Hezath Posted September 15, 2012 Share Posted September 15, 2012 I know it's a tad late now, but what about swapping to 330 stub axles? Quote Link to comment Share on other sites More sharing options...
be4ver Posted September 16, 2012 Author Share Posted September 16, 2012 Yeah that thought did cross my mind but thought that would be tricky to try find etc so I didn't even bother looking haha. And yeah, too late now anywho Quote Link to comment Share on other sites More sharing options...
