LWL1FE Posted March 4, 2012 Share Posted March 4, 2012 So i'm going through axles way to fast to source replacements and i'm keen to do the old school track day etc but can't source anymore axles and basically wouldn't trust them over the course of the weekend anyway. My plan is to do a conversion but i don't want to shorten the diff and i can only get another 5mm max out either side. My current e-series is around 1440 wide off the top of my head so what are my options? How will an f-series last? I can get an r31 diff which would be perfect but am yet to measure the width and don't know how strong it is. Would also like the option of an lsd. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted March 4, 2012 Share Posted March 4, 2012 F series are beefy compared to a E but hard to find a good width as most are from estima and around 1500mm wide Quote Link to comment Share on other sites More sharing options...
Spencer Posted March 4, 2012 Share Posted March 4, 2012 I had a 60 series with a live axle F series, start hunting! score an Altezza LSD after that, awesome for track days not so much for skids Quote Link to comment Share on other sites More sharing options...
LWL1FE Posted March 8, 2012 Author Share Posted March 8, 2012 I'm thinking 4wd liteace since (will confirm this weekend) the 2wd e-series have the same axles as the cressida so width should be mint. And yea altezza diff would be the plan. Whats the usual price for an altezza lsd? Quote Link to comment Share on other sites More sharing options...
HighLUX Posted March 8, 2012 Share Posted March 8, 2012 Yep 4wd liteace are F series Just got to redrill the stud pattern and do something about the huge spigot on the drum Quote Link to comment Share on other sites More sharing options...
ryanfels Posted March 8, 2012 Share Posted March 8, 2012 What have you got in it that keeps blowing axles? Quote Link to comment Share on other sites More sharing options...
mikuni Posted March 8, 2012 Share Posted March 8, 2012 What have you got in it that keeps blowing axles? viewtopic.php?t=28991 1g-gteu and an un sympathetic pair of boots Quote Link to comment Share on other sites More sharing options...
Shandangles Posted March 10, 2012 Share Posted March 10, 2012 do it once, do it right. hilux is the only answer Quote Link to comment Share on other sites More sharing options...
Roman Posted March 10, 2012 Share Posted March 10, 2012 Why bother, when there's an F series that will bolt straight in? I'd rather spend 6 months looking for a diff, than spending 6 months of tits for hands fabrication efforts making an abortion of shortening a diff. hilux diffs are only good if they're locked, unless you've got $$$$ to spend on buying an LSD that actually works properly. Quote Link to comment Share on other sites More sharing options...
LWL1FE Posted September 9, 2012 Author Share Posted September 9, 2012 note to those that care/want to do similar, i'm going to run a early 80's hilux diff purely because it's fractionally shorter (there are shorter again available but less common) and beacause g-series lsd is alot more common and cheap compared to f-series altezza liteace abominaton. Plus in the end it will still be stronger and apparently torsen lsd eats kaka Quote Link to comment Share on other sites More sharing options...
OldNathan Posted September 9, 2012 Share Posted September 9, 2012 What have you got in it that keeps blowing axles? http://www.oldschool.co.nz/phpbb/viewtopic.php?t=28991 1g-gteu and an un sympathetic pair of boots Im screwed Quote Link to comment Share on other sites More sharing options...
LWL1FE Posted September 9, 2012 Author Share Posted September 9, 2012 I found the e-series liteace axles are a better design so should last alot longer in theory (i havn't broken mine yet) Quote Link to comment Share on other sites More sharing options...
