felixx Posted March 3, 2012 Share Posted March 3, 2012 Ok so Mrs Felixx comes home in her starlet. "I think something is stuck under the car" I was looking for the cat/ dog/ child and couldnt see anyone/ thing jammed under car I took it for a drive and a rubbing noise (that is linked to your speed) occurs when you turn to the left. Came home, took wheel off, there appears to be a lot of life left in her pads (4mm or so) Sprayed brake clean in and around her brakes Wheel back on, noise is there. Maybe 4mm is not heaps left on pads (not up with the play on these modern things)? Any suggestions? Car is bog standard 1.3 auto FWD starlet Quote Link to comment Share on other sites More sharing options...
Beaver Posted March 3, 2012 Share Posted March 3, 2012 no loose mudflaps or inner wheel well guards etc? Quote Link to comment Share on other sites More sharing options...
fuel Posted March 3, 2012 Share Posted March 3, 2012 wheel bearings, CV joint, stone in brake caliper etc Quote Link to comment Share on other sites More sharing options...
Bling Posted March 3, 2012 Share Posted March 3, 2012 Unless the 4mm includes the backing plate, that is heaps of meat. As above, check the inner guards for shiny areas where the wheel could be rubbing. Is it at close to full lock or at any rate of turning? Quote Link to comment Share on other sites More sharing options...
felixx Posted March 3, 2012 Author Share Posted March 3, 2012 any amount of LH down made the noise, wasnt a CV joint type of clicking noise tho. Quote Link to comment Share on other sites More sharing options...
Slacker_Sam. Posted March 3, 2012 Share Posted March 3, 2012 Is there a stone stuck in the brakes like fuel said? or stuck behind the tin surround thing thats behind the brake rotor? Quote Link to comment Share on other sites More sharing options...
felixx Posted March 3, 2012 Author Share Posted March 3, 2012 could not see one, but that doesnt mean its not there.. I will have a look later, Cheers lads Quote Link to comment Share on other sites More sharing options...
felixx Posted March 4, 2012 Author Share Posted March 4, 2012 musta been a stone. Tried a reverse donut hard brakey thing .. Noise is gone Quote Link to comment Share on other sites More sharing options...
