10Speed Posted January 31, 2012 Share Posted January 31, 2012 As you can see the new foam pad is about 25mm too wide and 75mm too long? Should I trim it? I have looked at the cover and it seems to be a snug fit on the frame, so I am leaning towards trimming, but would like a second opinion... Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 31, 2012 Share Posted January 31, 2012 I would trim it, you wont notice small descrepancies once its covered up Quote Link to comment Share on other sites More sharing options...
Bling Posted January 31, 2012 Share Posted January 31, 2012 Not designed to wrap around the frame? I could be missing something... Quote Link to comment Share on other sites More sharing options...
10Speed Posted January 31, 2012 Author Share Posted January 31, 2012 I think it is designed so the foam edge fits around the frame... but it's all speculation Quote Link to comment Share on other sites More sharing options...
Simon Posted January 31, 2012 Share Posted January 31, 2012 I would hold off trimming it tbh. If it doesn't work you can just take the cover off and trim? Very hard to weld foam haha. Quote Link to comment Share on other sites More sharing options...
10Speed Posted February 1, 2012 Author Share Posted February 1, 2012 so as to tidily conclude this thread for future generations, I sliced a 25mm section out of the middle and glued the halves back together with ados spray adhesive and left the bottom untrimmed... Quote Link to comment Share on other sites More sharing options...
Bling Posted February 3, 2012 Share Posted February 3, 2012 Nice job! Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted February 3, 2012 Share Posted February 3, 2012 nice. can you feel the join at all? Quote Link to comment Share on other sites More sharing options...
10Speed Posted February 3, 2012 Author Share Posted February 3, 2012 no, the foam is under heaps of compression... when you start fitting the cover you'd swear it was 100mm to small.... Quote Link to comment Share on other sites More sharing options...
von Mako Posted February 4, 2012 Share Posted February 4, 2012 Nice job! Is that an off-the-shelf kit or did you have it made? I need to recover my seats Quote Link to comment Share on other sites More sharing options...
10Speed Posted February 4, 2012 Author Share Posted February 4, 2012 it's a TMI kit, though I think they're all made to order... Quote Link to comment Share on other sites More sharing options...
