pusherman Posted October 19, 2011 Share Posted October 19, 2011 pretty basic stuf but ive not done it befor i wana set my timing up nicely motor is a 1600, standard bore , blue printed, big valve head, some kind of cam, running twin 40 dellortos and decent extactors down to a 2+1/4 zaust. do i need to run any advance/rtard? in not going for extra performance just want the bitch to run nice also how the fuck do ya do gearbox oil? what oil to use? its a t9 siera 5 speed, when i got my drive shaft made i didnt bung the end up and gravity sucked my oil out. and while im at it i may aswell put new motor oil in what weight should i use? have asked this b4 but cnt b farked findn old thread. thanks for help guys Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 19, 2011 Share Posted October 19, 2011 Sorry but rather than typing all the advice out again - take a gander through your previous posts and find the answer from last time you asked. search.php?keywords=&terms=all&author=ben&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search If you have any questions that were not answered there then feel free to ask them. Quote Link to comment Share on other sites More sharing options...
pusherman Posted October 19, 2011 Author Share Posted October 19, 2011 thanks 4 that answered the engine oil question id asked many moons ago other questions still stand, it is intresting to browse back thru and see all the questions ive asked and hiccups ive overcum. thanks oldschool! Quote Link to comment Share on other sites More sharing options...
kritta Posted October 19, 2011 Share Posted October 19, 2011 best way i1ve found to do gearbox oil....take out filler plug on the side of gearbox, take out the shifter, and fill the gearbox from shifter housing, untill oil starts to flow out of filler on side of gearbox.....with the car LEVEL... Quote Link to comment Share on other sites More sharing options...
coldturkey Posted October 19, 2011 Share Posted October 19, 2011 best way i1ve found to do gearbox oil....take out filler plug on the side of gearbox, take out the shifter, and fill the gearbox from shifter housing, untill oil starts to flow out of filler on side of gearbox.....with the car LEVEL... Yeah this is the best way to do it. Some cars dont have drain bungs on the side though. I remember once I ran a long tube to a funnel on the roof of the car so there was enough gravity force to push the gearbox oil in to the side bung. It was a column shift where you obviously couldnt fill it through the shifter. In regards to timing, find a workshop manual and see what timing they are supposed to run standard, it will be a value of degrees at a certain RPM (eg. 8deg BTDC at 750rpm). Hook up your timing light, disconnect any vacuum advance hoses and rotate your dizzy until that setting is achieved. The factory setting is normally a good starting point, but you can tweak it a little if it doesnt sound right. If the above doesn't make sense to you then take it to any workshop. Atleast they will get it right and its only gonna take them half an hour or less if you specify you only want the timing set (not a full carb tune etc). Quote Link to comment Share on other sites More sharing options...
Raizer Posted October 19, 2011 Share Posted October 19, 2011 best way i1ve found to do gearbox oil....take out filler plug on the side of gearbox, take out the shifter, and fill the gearbox from shifter housing, untill oil starts to flow out of filler on side of gearbox.....with the car LEVEL... Doesn't work with an Escort box though since you cant fill them through the shifter. To drain take out the drive shaft and unbolt the gearbox crossmember from the car, lower the box as far as the engine mounts will twist. Fill it using a hose with a funnel stuck in one end run down the engine bay into the tunnel and yeah fill till the oil starts coming out of the filler hole in the side of the box. For a T9 if its in ok condition use 1.9L of 75W90 semi-synthetic oil. Quote Link to comment Share on other sites More sharing options...
