4evaevo Posted May 16, 2011 Share Posted May 16, 2011 Hi i am looking at converting a Altezza 3S-GE engine and 6speed box into my mk2 cortina. i was just wondering if anyone had done this before? do you guys think it will fit easily? Quote Link to comment Share on other sites More sharing options...
- i5oogt - Posted May 16, 2011 Share Posted May 16, 2011 yeah it has been done, there was a green mk2 sedan floating around palmerston north, it was on trademe for quite a while, i dont think it was certified tho Quote Link to comment Share on other sites More sharing options...
Truenotch Posted May 16, 2011 Share Posted May 16, 2011 There's a blue MK2 with a 7AFE? Haven't seen a beams one around here but it would be cool & you're probably right. Yes it can be done and would be the same difficulty as any Beams conversion into an old car. So you need: Engine, Gearbox, Factory engine + box mounts, Loom, ECU, Extractors, Driveshaft (to make a new one from) Then you'll need to make engine mounts fit which should be relatively straight forward if everything fits. The hard part will be wiring and fuelling. Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 17, 2011 Share Posted May 17, 2011 All depends on your skill level, wiring shouldnt be a problem just budget in a link unless you want to put all the RWD beams bits onto a Red top Beams. These have a easier computer to wire up (altezza one needs the dash and ignition to work) Appart from the usual stuff Markuu has pointed out, specifically for your car the sump on a beams just wont fit. The beams sump has a alloy top with a pressed steel bowl, I'd say you will have to make up a custom steel sump. Also I would say the gearbox tunnel will be tight Quote Link to comment Share on other sites More sharing options...
4evaevo Posted July 1, 2011 Author Share Posted July 1, 2011 what is a strong 4link rear end that is good for a cotina? Quote Link to comment Share on other sites More sharing options...
rxtoy Posted July 2, 2011 Share Posted July 2, 2011 Also note that the beams sump has internal oil galleries and a pressure regulating valve. Makes custom sumps that much more difficult. A mate welded up an alloy one for mine though, and we're just running the pressure regulator externally. Not sure if all beams are like this, I just know mine was. Altezza blacktop. Cheers Matt Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 2, 2011 Share Posted July 2, 2011 what is a strong 4link rear end that is good for a cotina? Start with a hilux diff and then custom 4 link parts required. There is no easy/best option for a mk2 Cortina unless you want to pay heaps and buy parts from Burton power and have someone wled them on.. Gaz Quote Link to comment Share on other sites More sharing options...
QCADTA Posted July 2, 2011 Share Posted July 2, 2011 check the height as well, theyre a tall engine. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted July 2, 2011 Share Posted July 2, 2011 check the height as well, theyre a tall engine. This, My mate started a project a few years ago, he has the beams mounted in his mk1 cortina, the throttle body is full of traction control wizardry and there is bugger all clearance for cam covers.. Project is on hold as he has gone to the UK for a bit... Quote Link to comment Share on other sites More sharing options...
