CaMpylobacter Posted February 17, 2011 Share Posted February 17, 2011 bigends having like a thou of wear causing pistons to clip head is my guess. probably number 4, especially due to a lazy oil pressure relief valve and added oil pressure demand from turbo being plumbed in has killed it. lel Quote Link to comment Share on other sites More sharing options...
Yowzer Posted February 17, 2011 Author Share Posted February 17, 2011 Sounds like the front of the engine, but can't really pinpoint it. Engine still feels to run sweet, but it is a pretty loud noise at idle that was not there yesterday. That would be mildly gay if that was the case though. Quote Link to comment Share on other sites More sharing options...
Jase Posted February 17, 2011 Share Posted February 17, 2011 engine mounts not torn from increased powers? or just typical diesel rattle or impending doom death rattle, tensioner hasn't worked loose on the cambelt? (loctited mine after impending doom rattle revealed it backed itself off) Quote Link to comment Share on other sites More sharing options...
Yowzer Posted February 17, 2011 Author Share Posted February 17, 2011 Doesn't look like engine mounts. Was thinking it could just be some sort of diesel rattle, but it got louder and more concerning. I cranked the tensioner up to spec, not really keen on pulling the whole front off again.. Will see if I can bend the cover back enough to get a look inside. Might find some high quality audio recording device for the sake of online diagnostics. Gonna be pretty gutted if it is something internal. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 17, 2011 Share Posted February 17, 2011 pull front off. not that hard broe. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted February 18, 2011 Author Share Posted February 18, 2011 I just woke up to the sudden realisation that I didn't do up the waterpump pulley bolts.. Most probably the source of the bizarre noise. Quote Link to comment Share on other sites More sharing options...
Hemi Posted February 18, 2011 Share Posted February 18, 2011 argh so sick of small noises and ticks making people think what they are running is fucked ! . ffs if there is a noise you cant track down and it still runs without loss of power etc who the fuck cares keep driving it till it comes out of the closet . the sound will either turn into a physical breakage or go away , then you have something to fix or not . dont fix shit that aint broke Quote Link to comment Share on other sites More sharing options...
keltik Posted February 18, 2011 Share Posted February 18, 2011 ^Possibly worst piece of advice ever? Makes more sense to hunt down noise and correct it before something goes wrong. Tightening water pump bolts seems easier than replacing pistons and valves because the loose pulley threw the cam belt. Quote Link to comment Share on other sites More sharing options...
Jase Posted February 18, 2011 Share Posted February 18, 2011 pump doesn't run off cambelt, couldn't possibly throw the cambelt as its got a massive plastic cover shielding it from the v belt set that runs all those ancillaries, good theory on tracking stuff down but L series diesels make weird noises as do a lot of others and will clatter away for years Quote Link to comment Share on other sites More sharing options...
keltik Posted February 18, 2011 Share Posted February 18, 2011 pump doesn't run off cambelt Ah, did not know this. Still, id rather fix/inspect pump than have some kind of disaster. Quote Link to comment Share on other sites More sharing options...
Hemi Posted February 18, 2011 Share Posted February 18, 2011 well when i made that post i was severly intoxicated ,i do however still stand by it . and im a mechanic , so there Quote Link to comment Share on other sites More sharing options...
Jase Posted February 18, 2011 Share Posted February 18, 2011 hemi zz Quote Link to comment Share on other sites More sharing options...
keltik Posted February 19, 2011 Share Posted February 19, 2011 and im a mechanic , so there Touche! Quote Link to comment Share on other sites More sharing options...
Yowzer Posted February 19, 2011 Author Share Posted February 19, 2011 well when i made that post i was severly intoxicated ,i do however still stand by it .and im a mechanic , so there TBH if I couldn't find it, that was what I was gonna do. Would have just ended up with a fan lodged in the radiator. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted February 19, 2011 Share Posted February 19, 2011 replaced head on a td27t and it had this horrendous knock that to me sounded like piston mashing into something. Car still idled and rev'd up fine-ish, I was convinced it was fucked but all we did was bleed it more and it ran mint. In closing, bleed it more. Maybe Quote Link to comment Share on other sites More sharing options...
