Goodmans 69 Mk2 Cortina
kiwitina
Im looking at buying some new door skins for a mk2 sport from that site how much did they rape you for shipping?
actually mate. your pretty much sorted for panels right here in NZ! check out palmside.co.nz. they have door skins and pretty much everything else. lucky bugger.
  • Replies 71
boss. I paid $50 + GST for powdercoating and sandblasting per wheel.
Send em down via OS Freight services and I shall t it up for ya
chur felix. i will see if I can find a better deal around auckland first. That is a damn good price though.
with your stuff you got from burton
did you get stung for gst when it got into nz ??
as im looking at geting some stuff my self
thanks
If you keep your order under NZ$1000. It should be ok. Yeah I made that mistake....
Hey mate,
I think you are going to have the same prob as me when fitting your M16 calipers to older style imperial (Cortina/early Capri) struts which have 7/16" mounting holes.
Not sure how to solve.
Either:
1. Use 7/16" bolts and shim the holes
2. Drill/Tap struts to 12mm - not sure there's enought material to do that
3. Saw in another forum that you can buy 7/16" bolts with a 12mm shoulder. Do these exist?
hi any one know where in aust i might be able to get the correct bolts for fitting m16 calipers onto capri struts they are 7/16 threads and have got a 12mm shoulder
Any problems dealing with Burtons? There's another crowd in the UK called GSEscorts which seem a little bit cheaper than Burtons but don't know too much about them.
Ya Tinas looking good by the way. :salute:
Mike
  • 3 months later...
Hey mate,
Either:
Mike
Hey Goodman, these are the bolts you need for mounting M16 calipers
http://www.ebay.co.u...=item2ec42f0777
Cheers
PS They are 18 pounds not 999.99 as listed. He's temporarily out of stock but should be available end next week.
  • 7 months later...
