kiwitina Posted November 10, 2010 Author Share Posted November 10, 2010 nah anglia in sig is not mine, just a pic i found online for inspiration/what it will look like when done.I have the box out of my anglia if you need the selector. Not sure if its the original anglia box though as it had an esky 1300 and the anglias originally have a hydraulic clutch which mine doesn't. Thanks man. Pretty sure I will be able to work with the one I have. Even if i have to bend or shorten it. chur Quote Link to comment Share on other sites More sharing options...
NaN Posted November 11, 2010 Share Posted November 11, 2010 Standard practice when painting conc is to remove any loose material via scraping.I would just leave with carpet tho as it is cheap/free! Gaz's 5c with no releveance to cars Worked for me just fine, no more concrete dust, no more lack of light under the car, .. all good. Sure there are better ways but it does work, and well. The downside to carpet is the 'hold in the dirt factor'. and when your using a hoist/lifter/engine stand the wheels bind on the carpet. oh .. SO relevant, the garage environment is just as relevant as the tools on the shadow board (if you have one). Quote Link to comment Share on other sites More sharing options...
mk2 cortina Posted November 28, 2010 Share Posted November 28, 2010 Hey mate, I'v got a mk2 myself, 5speed sierra box with a bench seat. I just moved up from Wellington to Auckland 2 weeks ago. Living out by Ardmore aerodrome. Keen to see how the Tina turns out!! Quote Link to comment Share on other sites More sharing options...
kiwitina Posted November 30, 2010 Author Share Posted November 30, 2010 Hey mate, I'v got a mk2 myself, 5speed sierra box with a bench seat. I just moved up from Wellington to Auckland 2 weeks ago. Living out by Ardmore aerodrome.Keen to see how the Tina turns out!! Always good to know of localish cortina drivers. Im from Pukekohe which is local enough i suppose. Think Im gonna stick with the 2000e gearbox in mine. might only be 4 gears but thats what I like about it. Close ratios too! Definitely staying with the bench seat. Will hopefully be done by this time next year!!! Quote Link to comment Share on other sites More sharing options...
- i5oogt - Posted December 8, 2010 Share Posted December 8, 2010 buy a spot weld drill bit to remove the front guards. dont chop them off as you need to keep the inner guard and top rail intact Quote Link to comment Share on other sites More sharing options...
kiwitina Posted December 11, 2010 Author Share Posted December 11, 2010 ":2znvl3df]buy a spot weld drill bit to remove the front guards. dont chop them off as you need to keep the inner guard and top rail intact Thanks mate. Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 11, 2010 Share Posted December 11, 2010 I have taken the guards off a mk2 before.. they are stuck on everywhere, tricky job which takes alot of patience. Gaz Quote Link to comment Share on other sites More sharing options...
kiwitina Posted December 11, 2010 Author Share Posted December 11, 2010 I have taken the guards off a mk2 before.. they are stuck on everywhere, tricky job which takes alot of patience.Gaz Yeah mate. I see its gonna be a tricky job. So was that off your current Mk2? How was the base of the A pillar once you got em off? From what I can see in mine, it doesn't seem that bad. The guard itself though is pretty shot so its gotta come off! Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 12, 2010 Share Posted December 12, 2010 Nah it was on my old mk2. Base of pillar was fine, infact whole car was fine When putting them back on make them bolt ons. Gaz Quote Link to comment Share on other sites More sharing options...
kiwitina Posted December 12, 2010 Author Share Posted December 12, 2010 Nah it was on my old mk2. Base of pillar was fine, infact whole car was fine When putting them back on make them bolt ons. Gaz yeah for sure. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted December 26, 2010 Share Posted December 26, 2010 And use riv nuts Looks like you have a fairly mint shell seen alloy worse Quote Link to comment Share on other sites More sharing options...
kiwitina Posted December 26, 2010 Author Share Posted December 26, 2010 And use riv nuts Looks like you have a fairly mint shell seen alloy worse Benefits of spending a bit extra and getting a car that was on road I guess. Looks to be in original condition but I cant really tell. Riv nuts??? rivet nuts i assume?? cant think if i've ever seen them. Chur Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted December 26, 2010 Share Posted December 26, 2010 http://www.google.co.nz/images?hl=en&q= ... 38&bih=544 Use them for everything Quote Link to comment Share on other sites More sharing options...
kiwitina Posted December 27, 2010 Author Share Posted December 27, 2010 http://www.google.co.nz/images?hl=en&q=riv+nuts&um=1&ie=UTF-8&source=og&sa=N&tab=wi&biw=1138&bih=544Use them for everything ahhh I see. will do. thanks for the advice. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted February 9, 2011 Share Posted February 9, 2011 Buy two solid engine stands, chop and weld to suit. Quote Link to comment Share on other sites More sharing options...
kiwitina Posted February 10, 2011 Author Share Posted February 10, 2011 Buy two solid engine stands, chop and weld to suit. haha I previously wasn't sold on this idea. I dont know why. Guess it just seemed budgo to me but now it all makes cost cutting sense. Thanks mate. You've saved me a small fortune. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 13, 2011 Share Posted July 13, 2011 That two door doesnt look in to bad condition. Slap it on tardme you might be supprised, they are quite rare. Quote Link to comment Share on other sites More sharing options...
kiwitina Posted July 13, 2011 Author Share Posted July 13, 2011 Ive sold it. Might have kept it if it was good for that reason but its totally screwed. Sills, floors, boot, front and rear guards and posts To big a job for someone like me who doesnt know how to weld yet. Apparently what is salvageable will be used on another 2 door so that atleast is good. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted January 28, 2012 Share Posted January 28, 2012 That dash looks sweet. And the steering wheel too. Quote Link to comment Share on other sites More sharing options...
NaN Posted April 9, 2012 Share Posted April 9, 2012 should make yourself a rolling frame so you can have the suspension off and still roll the car out of the garage and get the benefit of a empty garage when you need it. Quote Link to comment Share on other sites More sharing options...
