kiwitina Posted July 28, 2012 Author Share Posted July 28, 2012 Im looking at buying some new door skins for a mk2 sport from that site how much did they rape you for shipping? actually mate. your pretty much sorted for panels right here in NZ! check out palmside.co.nz. they have door skins and pretty much everything else. lucky bugger. Quote Link to comment Share on other sites More sharing options...
felixx Posted August 1, 2012 Share Posted August 1, 2012 boss. I paid $50 + GST for powdercoating and sandblasting per wheel. Send em down via OS Freight services and I shall t it up for ya Quote Link to comment Share on other sites More sharing options...
craw Posted August 1, 2012 Share Posted August 1, 2012 with your stuff you got from burton did you get stung for gst when it got into nz ?? as im looking at geting some stuff my self thanks Quote Link to comment Share on other sites More sharing options...
kiwitina Posted August 2, 2012 Author Share Posted August 2, 2012 boss. I paid $50 + GST for powdercoating and sandblasting per wheel.Send em down via OS Freight services and I shall t it up for ya chur felix. i will see if I can find a better deal around auckland first. That is a damn good price though. with your stuff you got from burtondid you get stung for gst when it got into nz ?? as im looking at geting some stuff my self thanks If you keep your order under NZ$1000. It should be ok. Yeah I made that mistake.... Quote Link to comment Share on other sites More sharing options...
craw Posted August 3, 2012 Share Posted August 3, 2012 cool thanks for that Quote Link to comment Share on other sites More sharing options...
mfordy Posted August 11, 2012 Share Posted August 11, 2012 Hey mate, I think you are going to have the same prob as me when fitting your M16 calipers to older style imperial (Cortina/early Capri) struts which have 7/16" mounting holes. Not sure how to solve. Either: 1. Use 7/16" bolts and shim the holes 2. Drill/Tap struts to 12mm - not sure there's enought material to do that 3. Saw in another forum that you can buy 7/16" bolts with a 12mm shoulder. Do these exist? hi any one know where in aust i might be able to get the correct bolts for fitting m16 calipers onto capri struts they are 7/16 threads and have got a 12mm shoulder Any problems dealing with Burtons? There's another crowd in the UK called GSEscorts which seem a little bit cheaper than Burtons but don't know too much about them. Ya Tinas looking good by the way. Mike Quote Link to comment Share on other sites More sharing options...
kiwitina Posted August 11, 2012 Author Share Posted August 11, 2012 Thanks for the heads up mike. I will look into it. Quote Link to comment Share on other sites More sharing options...
kseries.rookie Posted August 15, 2012 Share Posted August 15, 2012 Hey buddy. What are those strip discs that you used to take back the paint? Looking good man, its going to be awesome once its done mate Quote Link to comment Share on other sites More sharing options...
kiwitina Posted August 15, 2012 Author Share Posted August 15, 2012 A company called Smith and Arrow make em. You can find them on trade me. http://www.trademe.co.nz/business-farmi ... 032170.htm or search users for listings by 'smithandarrow'. They are the best. Far better than those 3m things. Chur Quote Link to comment Share on other sites More sharing options...
mfordy Posted December 7, 2012 Share Posted December 7, 2012 Hey mate, I think you are going to have the same prob as me when fitting your M16 calipers to older style imperial (Cortina/early Capri) struts which have 7/16" mounting holes. Not sure how to solve. Either: 1. Use 7/16" bolts and shim the holes 2. Drill/Tap struts to 12mm - not sure there's enought material to do that 3. Saw in another forum that you can buy 7/16" bolts with a 12mm shoulder. Do these exist? Any problems dealing with Burtons? There's another crowd in the UK called GSEscorts which seem a little bit cheaper than Burtons but don't know too much about them. Ya Tinas looking good by the way. Mike Hey Goodman, these are the bolts you need for mounting M16 calipers http://www.ebay.co.u...=item2ec42f0777 Cheers PS They are 18 pounds not 999.99 as listed. He's temporarily out of stock but should be available end next week. Quote Link to comment Share on other sites More sharing options...
far4ngn Posted December 30, 2012 Share Posted December 30, 2012 Wow interesting read, good job. Quote Link to comment Share on other sites More sharing options...
junglesponge Posted August 22, 2013 Share Posted August 22, 2013 Hey mate your cortina is mean and gives me motivation to keep doing mine. Quote Link to comment Share on other sites More sharing options...
