escort not starting
mk2escort
Well tonight I went to start my escort (1.3 standard) and wouldnt start all dash lights ect where working but wouldnt even turn over. It just makes a single clunking noise when i turn key. I dont really know much about cars but am assuming the starter motors died so before i go buy another one is there anything else i should check?? thanks
check earth and battery terminals. make sure stater motor is getting enough juice. try giving it a jumpstart, will tell you if its the starter motor or not. sounds like its just not getting enough juice though
trying not to ask a dumb question here but are you sure the battery isn't flat as it dosn't take alot of power for dash lights to go takes a bit more for it to wind over?
If the starter's attempting to work, then everything will go dim/out on the dash if the battery's low. Stick the headlights on as well to be sure.
Is it an auto? Run it through to D then back to Park if so.
Had this with the trump a few times before conversion, was the inhibitor switch not realising it was in fact in park.
wouldnt even start to turn if this was the case .
i reckon the clunk is the solinoid engaging but the starter brushes sticking or being worn .
