danger Posted December 14, 2009 Share Posted December 14, 2009 Amateur questions but thought a few of you lot will have no doubt found a few wee tricks and treats Best cheap way to lower the fronts? What shorter shocks fit teh rears? Easiest way to bolt in a couple of AE111 pews in the front? Not sure if I should attempt to mod old rails to new seats or just make new base plates Quote Link to comment Share on other sites More sharing options...
4AG_Addict Posted December 14, 2009 Share Posted December 14, 2009 KE70 Wagon Shocks for the rear, in the front you can use 4WD Carib front inserts (can't think of chassis right now), same body size, but 30mm shorter stroke. Or if you want to put a spacer in shock tube, then ST185 GT4 Inserts or AE92 Levin are much shorter. Photo below is all captive with 3 or 3&1/2 coils removed all round, ke70 rear shock, carib front Quote Link to comment Share on other sites More sharing options...
Ned Posted December 14, 2009 Share Posted December 14, 2009 Front i used cobra super lows and gor some KYB shocks shortened 2 to 3 inches. Rear was KE70 shocks with cobra superlows. Cost me 750 all up years ago (new) Quote Link to comment Share on other sites More sharing options...
danger Posted December 14, 2009 Author Share Posted December 14, 2009 Cheers guys. Think i'll have old ke70 shocks around too. Saves me fucking round. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 14, 2009 Share Posted December 14, 2009 ke70 wagon shocks for really small springs, but sedan for medium low Quote Link to comment Share on other sites More sharing options...
danger Posted December 14, 2009 Author Share Posted December 14, 2009 Well its currently sitting on superlows -2 coils so think the wagon ones shall be the go Quote Link to comment Share on other sites More sharing options...
g carmatic Posted January 7, 2010 Share Posted January 7, 2010 do you know if the carib inserts will fit in ke20 struts? cheers Quote Link to comment Share on other sites More sharing options...
Snoozin Posted January 7, 2010 Share Posted January 7, 2010 KE20 from memory use the same size strut housing. I'm using Mk2 Golf diesel front inserts in my coilovers, about 60-70mm shorter in total. Nice stiff valving also. Quote Link to comment Share on other sites More sharing options...
