forced Posted November 6, 2009 Share Posted November 6, 2009 That always happens with a blown headgasket. Oh and when the car is moving, a fan isn't even needed. Steve Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 6, 2009 Share Posted November 6, 2009 take the thermostat out and go for a drive, if it doesn't overheat buy a new thermostat was thinking water pump aswell, i just stripped an over heated motor today to find no blades left on the pump they had all rusted off. but then i saw yours was relatively new so oh well Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 6, 2009 Share Posted November 6, 2009 That always happens with a blown headgasket.Oh and when the car is moving, a fan isn't even needed. Steve but if the fan is going the wrong way it would be a hindrance while moving so worth checking Quote Link to comment Share on other sites More sharing options...
Elmo2003 Posted November 6, 2009 Author Share Posted November 6, 2009 do 33s have the bleed bolt on the plenum that you take out while filling the radiator? RB engines can be cunts to get all the air out of the coolant system so you may have an air lock yea i have done the air lock thing with the bleed valve there is no air in the system so..... i am running out of ideas Quote Link to comment Share on other sites More sharing options...
Hemi Posted November 7, 2009 Share Posted November 7, 2009 do 33s have the bleed bolt on the plenum that you take out while filling the radiator? RB engines can be cunts to get all the air out of the coolant system so you may have an air lock yea i have done the air lock thing with the bleed valve there is no air in the system so..... i am running out of ideas i think a full load stationary cooling test is needed to confirm siad problem heres a how to: you laugh , i had an overheating problem and did somthing similar ..it fixed it Quote Link to comment Share on other sites More sharing options...
Elmo2003 Posted November 7, 2009 Author Share Posted November 7, 2009 do 33s have the bleed bolt on the plenum that you take out while filling the radiator? RB engines can be cunts to get all the air out of the coolant system so you may have an air lock yea i have done the air lock thing with the bleed valve there is no air in the system so..... i am running out of ideas i think a full load stationary cooling test is needed to confirm siad problem heres a how to: you laugh , i had an overheating problem and did somthing similar ..it fixed it yea doing burnouts aint guna help my problem apart from possibly make it worse Quote Link to comment Share on other sites More sharing options...
Elmo2003 Posted November 7, 2009 Author Share Posted November 7, 2009 its not somthing silly like the thermo fan blowing through the rad ?? , some fans only work one way aka if you reverse current they dont blow etcdo r33 have a viscous fan from factory?? , if so i would have kept that , dunno why everyone changes to electric , the amount of power you save nothing compared to the amount of suck mech fan can dish out yea i would of kept the viscous fan but ddnt fit wen i put my intercooler piping in fan kept hitting pipe i dnt thnk it the fan nt sucking enough air az it is blowing hot air on to motor and drawing cool air thru radiator and thru a/c radiator so i would assume by that that the fan is doing its job Quote Link to comment Share on other sites More sharing options...
Hemi Posted November 7, 2009 Share Posted November 7, 2009 its not somthing silly like the thermo fan blowing through the rad ?? , some fans only work one way aka if you reverse current they dont blow etcdo r33 have a viscous fan from factory?? , if so i would have kept that , dunno why everyone changes to electric , the amount of power you save nothing compared to the amount of suck mech fan can dish out yea i would of kept the viscous fan but ddnt fit wen i put my intercooler piping in fan kept hitting pipe i dnt thnk it the fan nt sucking enough air az it is blowing hot air on to motor and drawing cool air thru radiator and thru a/c radiator so i would assume by that that the fan is doing its job is it enough though?? you say in heavy traffic and under load , if the fan is not creating enough flow over the rad thenit could very well be the prob , then again even under load on the highway there should be enough airflow regaurdless Quote Link to comment Share on other sites More sharing options...
Elmo2003 Posted November 7, 2009 Author Share Posted November 7, 2009 its not somthing silly like the thermo fan blowing through the rad ?? , some fans only work one way aka if you reverse current they dont blow etcdo r33 have a viscous fan from factory?? , if so i would have kept that , dunno why everyone changes to electric , the amount of power you save nothing compared to the amount of suck mech fan can dish out yea i would of kept the viscous fan but ddnt fit wen i put my intercooler piping in fan kept hitting pipe i dnt thnk it the fan nt sucking enough air az it is blowing hot air on to motor and drawing cool air thru radiator and thru a/c radiator so i would assume by that that the fan is doing its job is it enough though?? you say in heavy traffic and under load , if the fan is not creating enough flow over the rad thenit could very well be the prob , then again even under load on the highway there should be enough airflow regaurdless yea it dnt over heat on open roads unless it a steep hill and u hav to go slow up it eg following trucks etc so i dnt kw i am jst about over the whole car i do want get it sorted tho as it a nice car to drive but wot a drama Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 7, 2009 Share Posted November 7, 2009 did you try the thermostat? my beemer used to overheat occasionally due to a shit but brand new genuine bmw thermostat worth a try Quote Link to comment Share on other sites More sharing options...
Elmo2003 Posted November 7, 2009 Author Share Posted November 7, 2009 did you try the thermostat? my beemer used to overheat occasionally due to a shit but brand new genuine bmw thermostatworth a try no havent tried that yet that is next on the list of things to try so fingers crossed that all it is Quote Link to comment Share on other sites More sharing options...
Hemi Posted November 7, 2009 Share Posted November 7, 2009 did you try the thermostat? my beemer used to overheat occasionally due to a shit but brand new genuine bmw thermostatworth a try yea and i dont know about rbs but if its a thermo with a block thing at the bottom and its not there i destroys all water flow . that wont help Quote Link to comment Share on other sites More sharing options...
Elmo2003 Posted November 7, 2009 Author Share Posted November 7, 2009 did you try the thermostat? my beemer used to overheat occasionally due to a shit but brand new genuine bmw thermostatworth a try yea and i dont know about rbs but if its a thermo with a block thing at the bottom and its not there i destroys all water flow . that wont help i dnt kw aye really here is wot it looks like http://www.trademe.co.nz/Trade-Me-Motor ... 677441.htm Quote Link to comment Share on other sites More sharing options...
Borgweiser Posted November 7, 2009 Share Posted November 7, 2009 weld some fins on the block and head and chuck a giant fan on it. Aircooling = win Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 7, 2009 Share Posted November 7, 2009 yea sorry man, should have clicked and readwhat state is your water pump in? pump should be good got it changed wen cambelt etc got done round 5000kms ago the top radiator pipe is getting quite pressurized compared to the bottom this would say that the thrmostat aint opening yes or no This screams to me that you have a flow restriction in the radiator - I would get it cleaned out.. At the same time replace the thermostat for peace of mind. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted November 7, 2009 Share Posted November 7, 2009 Having a good rad cap keeps the system under pressure. The fluid in the system will behave differently at different pressure levels. Quote Link to comment Share on other sites More sharing options...
forced Posted November 7, 2009 Share Posted November 7, 2009 The top tank of the radiator will let the pressure out instead when it bursts. Steve Quote Link to comment Share on other sites More sharing options...
Elmo2003 Posted November 8, 2009 Author Share Posted November 8, 2009 yea sorry man, should have clicked and readwhat state is your water pump in? pump should be good got it changed wen cambelt etc got done round 5000kms ago the top radiator pipe is getting quite pressurized compared to the bottom this would say that the thrmostat aint opening yes or no This screams to me that you have a flow restriction in the radiator - I would get it cleaned out.. At the same time replace the thermostat for peace of mind. so would using a liquid radiator flush do the trick or would it be best taking it to a radiator shop to get tanks taken off etc Quote Link to comment Share on other sites More sharing options...
Elmo2003 Posted November 8, 2009 Author Share Posted November 8, 2009 Having a good rad cap keeps the system under pressure. The fluid in the system will behave differently at different pressure levels. the radiator cap is the stock one that came with car from factory i may change it soon but i mite do thermostat and flush radiator Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 8, 2009 Share Posted November 8, 2009 so would using a liquid radiator flush do the trick or would it be best taking it to a radiator shop to get tanks taken off etc Nah flush is only to clean the scale and sludge out of a cooling system, it won't unblock it - however it shouldnt cost you more than $70 or $80 to get it stripped and rodded out. I'm also getting the feeling you are trying to find an easy shortcut to fix your overheating problems - there is no shortcut on these problems, remove the radiator and have it proffessionally cleaned and I feel you will sort your issue. Quote Link to comment Share on other sites More sharing options...
