KKtrips Posted November 8, 2009 Share Posted November 8, 2009 just FYI - I have spent a lot of time on several vehicles fixing overheating issues and have been successful after many many hours and $$$ spent. I managed to get a 320hp Small Block Chev cooling through a radiator the size of 21" telly with persistence and doing the right thing.. Quote Link to comment Share on other sites More sharing options...
Elmo2003 Posted November 8, 2009 Author Share Posted November 8, 2009 so would using a liquid radiator flush do the trick or would it be best taking it to a radiator shop to get tanks taken off etc Nah flush is only to clean the scale and sludge out of a cooling system, it won't unblock it - however it shouldnt cost you more than $70 or $80 to get it stripped and rodded out. I'm also getting the feeling you are trying to find an easy shortcut to fix your overheating problems - there is no shortcut on these problems, remove the radiator and have it proffessionally cleaned and I feel you will sort your issue. ok sweet i will gt on to doing thermostat,engine flush and get the radiator rodded out jst to be on the safe side then i will kw that all me flow issues will b covered Quote Link to comment Share on other sites More sharing options...
forced Posted November 8, 2009 Share Posted November 8, 2009 Have you thought about hooking up a boost gauge to your cooling system and taking it for a drive? BTW modded turbo cars can easily make 800 HP on a stock radiator. Steve Quote Link to comment Share on other sites More sharing options...
mixmasterlex Posted November 9, 2009 Share Posted November 9, 2009 BTW modded turbo cars can easily make 800 HP on a stock radiator. Are you serious? That's a terrible gereralisation. Quote Link to comment Share on other sites More sharing options...
