CaMpylobacter Posted September 16, 2009 Share Posted September 16, 2009 mean Quote Link to comment Share on other sites More sharing options...
mixmasterlex Posted September 16, 2009 Share Posted September 16, 2009 badboy. post vid of skids on laundy detergent and water please. Quote Link to comment Share on other sites More sharing options...
Alistair Posted September 17, 2009 Author Share Posted September 17, 2009 So now its legal begal ive been riding it moar. And after riding around for 5-10 minutes itll start to lose pow pow and be gay. If i turn it off for a couple minutes then back on it goes meke for a bit longer. Bear it mind I have no experience with bikes/scooters/mopeds whatsoever. Quote Link to comment Share on other sites More sharing options...
10Speed Posted September 17, 2009 Share Posted September 17, 2009 air leaks? Quote Link to comment Share on other sites More sharing options...
Alistair Posted September 17, 2009 Author Share Posted September 17, 2009 From? Quote Link to comment Share on other sites More sharing options...
10Speed Posted September 17, 2009 Share Posted September 17, 2009 http://www.mopedarmy.com/wiki/Vacuum_leak but in a nutshell: Spray carb cleaner (some people use WD-40) anywhere two metal surfaces join. Make sure you spray only one area at a time; don't just bathe the whole engine area in carb cleaner all at once. If you hear the idle change or the engine dies, there is an air leak at the place you just sprayed. Quote Link to comment Share on other sites More sharing options...
Alistair Posted September 17, 2009 Author Share Posted September 17, 2009 Interesting, will give that a go tomorrow! Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 17, 2009 Share Posted September 17, 2009 Because you're so busy at work now? Quote Link to comment Share on other sites More sharing options...
Alistair Posted September 17, 2009 Author Share Posted September 17, 2009 Gotta take it easy chump Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 17, 2009 Share Posted September 17, 2009 Easy, Breezy, Beautiful, CoverBoy. Quote Link to comment Share on other sites More sharing options...
Alistair Posted September 18, 2009 Author Share Posted September 18, 2009 Found an air leak where the carb bowl seals to the top of the crab. Have sealed up, will test to see if fixed layter. Quote Link to comment Share on other sites More sharing options...
Steelies Posted September 18, 2009 Share Posted September 18, 2009 also possible fuel vapourisation when its getting hot? i remember an old codger telling me it used to happen on his machines of travelation till he protected the fuel system from exhaust heat or ran a line elsewhere Quote Link to comment Share on other sites More sharing options...
tortron Posted September 18, 2009 Share Posted September 18, 2009 cone^ minor fuel lines run between the firewall and the exhaust - not the best Quote Link to comment Share on other sites More sharing options...
