ESKIN8R Posted March 21, 2009 Share Posted March 21, 2009 For those of you that have fitted pintos to eskys, what radiator did you use?? Dont wanna have to chop too much. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 21, 2009 Share Posted March 21, 2009 apparently 1600 ones are OK otherwise just fit a mk3 or there abouts 2l cortina one. hardly any modification required. Pick a part is good for finding these. Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 21, 2009 Share Posted March 21, 2009 Austin 1100 rad boe. Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 22, 2009 Share Posted March 22, 2009 Just use the standard 1600 rad. No cutting etc needed. 1600 core size is the same as 2l mk3/mk4/mk5 cortina rads so they WILL cool the 2l garunteed. Its what I ran on my first conversion. Ran the mk4 rad on my 2nd and made a 3 core on my third. On my mk2 Cortina I run the standard rad which is a diff one again and it cools. So thats another option. 1600 escort is the easiest tho. Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 22, 2009 Share Posted March 22, 2009 1600 being 1600 crossflow radiator right? Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 22, 2009 Share Posted March 22, 2009 Yeah 1600 Xflow rad. Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 22, 2009 Share Posted March 22, 2009 Yeap yeap. Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 22, 2009 Share Posted March 22, 2009 how do you tell the difference between a 1600 and a 1300 rad? is it thickness or height or width? Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 22, 2009 Share Posted March 22, 2009 Height, same as the engine blocks the 1300 is taller than 1100, 1600 is taller than the 1300. Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 22, 2009 Share Posted March 22, 2009 Yeap its in the height. 1600 is quite a bit taller than 1300 rad. I can measure tommorrow if you want? Quote Link to comment Share on other sites More sharing options...
escorted Posted March 22, 2009 Share Posted March 22, 2009 I running my 1300 radiator at the moment. Its not exactly perfect so i would go with a 1600 or A pinto 1 Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 22, 2009 Share Posted March 22, 2009 yeah would be cool if you could measure, they still go on the same mounting points? Quote Link to comment Share on other sites More sharing options...
escorted Posted March 22, 2009 Share Posted March 22, 2009 yeah would be cool if you could measure, they still go on the same mounting points? 1600 will Pinto you need to swap the brackets around Quote Link to comment Share on other sites More sharing options...
