Ke36 Posted March 2, 2009 Share Posted March 2, 2009 hey guys trying to make a short shifter for my lancer just wondering is the square bit just above the red line in this pick there to hit the "gate" when you change into 5th gear?stopping you from hitting reverse when downchanging it would be easier to cut and weld below it but if it does do that i will need to cut and weld on the other side of it cheers Quote Link to comment Share on other sites More sharing options...
Vai-Man Posted March 2, 2009 Share Posted March 2, 2009 I know on a old chevette it had a bit like that to stop it going into reverse insted of first so assume it is for 5th/reverse i wouldnt go cutting it lol Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted March 2, 2009 Share Posted March 2, 2009 Let us kow how you get on with making this. Id like to copy it Quote Link to comment Share on other sites More sharing options...
David Posted March 2, 2009 Share Posted March 2, 2009 Been about 10 years since i've played with lancers but just wondering if you need to weld anything. I've done Hillman ones before and they have a nylon ball on the shaft with a pin holding it in place. So just need the hole in the shaft drilled about 4mm higher up the shaft and pined at that point. Then a 4mm spacer needs to be put between the selector mount and the box. A bit of alloy and a hole-saw made this plate nicely. I could be on the wrong track as the japa stuff could be different. The part your showing isn't what prevents the gearstick turning around? Quote Link to comment Share on other sites More sharing options...
Ke36 Posted March 3, 2009 Author Share Posted March 3, 2009 have a looksee here guys viewtopic.php?f=18&t=10961&start=80 Quote Link to comment Share on other sites More sharing options...
lowlancer Posted March 3, 2009 Share Posted March 3, 2009 I'm pretty sure it's what locks in when you press in for reverse Quote Link to comment Share on other sites More sharing options...
Ke36 Posted March 4, 2009 Author Share Posted March 4, 2009 ah sweet doesnt matter now as i cut above it to keep it the same distance from the ball anyways Quote Link to comment Share on other sites More sharing options...
