kpr Posted December 18, 2011 Author Posted December 18, 2011 last weekend W box fail gimme a t50 anydayum... Quote
kpr Posted January 13, 2012 Author Posted January 13, 2012 kinda boring update. but this is all fixed and running again. changed alot of stuff around. although nothing exciting to look at. new cusco engine mounts more heat sheilding redone turbo waterlines move steering rack forward to sort out over centering at high lock. new bottom end, its basically a smallport 4agze long block now, with trd head gasket to bump compression up into the 9's. arp rod bolts and balance, etc. done a few k's in it to run in. feels strong and not as lazy as i thought it would. will wind at least 15psi into it. 200kw at wheels should be easy. Quote
kpr Posted March 25, 2012 Author Posted March 25, 2012 went to a drift day at hampton on sat. first day on a dry full track. car was handing real well. but had a some missfiring issues due to a dead plug. but managed to sort it and do a few decent runs. then ran out of tyres.some vids bro took: theres a few pics on blog also Quote
kpr Posted September 15, 2012 Author Posted September 15, 2012 long time no update. just finished changing the cooling setup had the intercooler mounted like this. which sucked for flow to the radiator. even with ducting chopped up the intercooler again! welded on new feed pipes. still not the best way for the inlet/outlets. but no worse that what it was. mounted it here new twin fans new intake will upload more soon. Quote
kpr Posted September 15, 2012 Author Posted September 15, 2012 half way through doing this. i discovered the long side of the bottom radiator tank, was restricted to about half. bottom pipe was welded on wrong. love those chinese products! blanking plates to stop air escaping out the side, plus new poser bonnet latch support existing tray, bolts to bottom of bumper bonnet seals off top hole fairly well. seems to work good on test run, kinda hard to beat down on it enough around here. but temp seems to stay around 82deg with fans off. running 17psi now. keeps frying the tyres in 3rd, which is making it hard to tune! might have to take it to dyno. Quote
kpr Posted May 31, 2014 Author Posted May 31, 2014 Digging this up from the dead. After doing the above stuff almost 2 years ago. It sprung a leak in the sump, I got angry, done a skid up the road and parked it up. Still ain't fixed. Until today, pulled most of it apart , engine ready to come out. Plan is to fix gearbox and sump. then change a whole lot of other stuff that annoys me. Coupe Lyfe Quote
kpr Posted June 3, 2014 Author Posted June 3, 2014 mmm messy that's right i have actually done something. interior is about in the same state. Stinky old w-box was pretty close to pulling the trigger on a j160. but got a rebuild kit on the way from murica, for a good price. so will give it one more chance. in other news. inlet manifold is cracked again. whole new setup time im thinking. diff is leaky, maybe needs new pinion bearing also. sump is fixed! need to make another one of these too, boring stuff = boring update. Quote
kpr Posted July 20, 2014 Author Posted July 20, 2014 gearbox rebuilt managed to rebuild the whole thing without a press. new bearings, syncro's, seals etc. above is my "special service tool" for getting 5th gear off the output shaft. Used some cheese chinese pullers and the one below, to get the rest apart. used to pull some of the gears/bearings back onto the shafts also, as below. seems to work on the bench. this is the "good condition w58" i brought off that shit kicker. still nothing too exciting happening so heres a skid. still looking for some blacktop throttles and a 2wd hilux driveshaft.. Quote
kpr Posted August 24, 2021 Author Posted August 24, 2021 @Dudley was trying to keep it under wraps bro. but since you blew my cover Quote
Popular Post kpr Posted April 4, 2025 Author Popular Post Posted April 4, 2025 Other than the regular updates ; This has obviously been sitting for 10 years or so. Since i cant choose what other engine to put in it. its getting another 4age. Plan its to make it run and drive nice. Because I already have a rattly kp that will always be faster I could just turbo a stock engine and it would do those things and also be faster. but done that and would be boring and too easy. So the only logical thing was to get a smallport head, and cut the inlet ports off in my lathe mill Insert stuff i dont want to show yet lots more butchery, welding and stuff I basically had to cut way down into the port and add a bunch of material and cut a bunch out in other places. So it actually makes the short turn radius better. I'd looked into doing it many times before, but seemed pointless unless went full ham. originally i was going to weld the pipes below directly to the head. but they ended up so high on the head, that it wasn't going to be possible. so welded a flange to the head instead, for a bolt on manifold. More work, but better for many reasons High port vs stock port Is a bit more port work to go, but the basic shape is roughed out. Angle looks pretty aggressive when in the car. Will be running 48mm bike e throttles, same as what @Roman ran on the 1nz. the outer runners/ports are tweaked in a touch to line up with the outside throttles, otherwise line up good. 29 6 Quote
Popular Post kpr Posted April 5, 2025 Author Popular Post Posted April 5, 2025 Intake ports almost finished can see how much the ports have moved compared to the picture i stole off the internet below / update 22 5 Quote
