Jase Posted July 26, 2008 Share Posted July 26, 2008 looking into zinc plating all my suspension stuff will it work on springs? does it build much ie will it be trouble for putting bushes back in Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted July 26, 2008 Share Posted July 26, 2008 Nah shouldnt do, I had a whole pile of bolts zinc plated and they still screwed into their holes fine. Quote Link to comment Share on other sites More sharing options...
Jase Posted July 27, 2008 Author Share Posted July 27, 2008 cheers man , can't stand rust or grime so i want to be able to waterblast it and have it look sweet with minimal effort unlike chipped powdercoat etc Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 27, 2008 Share Posted July 27, 2008 Whats zinc plating cost say in comparison to powder coating? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 27, 2008 Share Posted July 27, 2008 I had all the Mercedes project nuts and bolts that I didn't buy new grey or yellow Zinced and they looked great. No issues with thread bind. I don't know that it is a good idea on springs though. The heat may make them brittle? Best to check with someone in the industry. I am having a boat trailer re-galvanized late next week and they don't want to touch the leaf springs Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted July 28, 2008 Share Posted July 28, 2008 cracks and falls off after a few compressions and your left with a yuck looking spring.... best to get springs blasted and powdercoated...that way you get a lasting finish they do a ":like" metalic silver powdercoat looks fantastic Quote Link to comment Share on other sites More sharing options...
mikuni Posted July 28, 2008 Share Posted July 28, 2008 does powdercoating flex enough to stay on a spring? I always thought it was quite hard and brittle Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted July 28, 2008 Share Posted July 28, 2008 Oi heaps of after market springs are powder coated if the do it properly and thick its basically a plastic coating only cheap/thin jobs crack cheap bbq's etc, oh and its diddy Quote Link to comment Share on other sites More sharing options...
Jase Posted July 29, 2008 Author Share Posted July 29, 2008 will just paint the springs then and put some dh bike tube over them completely will stop them pesky stones getting in a sittin on my lower arm and spring mounts, cheers fellas Quote Link to comment Share on other sites More sharing options...
Hemi Posted July 29, 2008 Share Posted July 29, 2008 zinc coating ftw! coaxed mate at work who built trailer for his quad to do it with a 10 yr garuntee you cant really go wrong . also nah ive seen the zinc crack under stratch and compression and the heats they use for hot dip although not extremely high, i wouldnt put anything heat treated near them for piece of mind Quote Link to comment Share on other sites More sharing options...
peteretep Posted July 29, 2008 Share Posted July 29, 2008 what kind of prices is it? id be keen to get all the bolts on my car done but i think id forget which one went where... also, do the bolts need to be clean(hard to get get out stuff) or does the process burn all the crap off the bolts Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 29, 2008 Share Posted July 29, 2008 ^ Cheap. Bolts don't need to be that clean as they dunk them in acid. The boat trailer is going to cost $2 per kilo of the parent metal to be galvanised. The trailer is about 5 meters long and I guess weighs 130 kgs. All the bolts etc. that I did for the Mercedes came to about $80 I guess Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted July 30, 2008 Share Posted July 30, 2008 Yeah I did half an icecream container of nuts & bolts and it cost me $30. Quote Link to comment Share on other sites More sharing options...
Jase Posted August 7, 2008 Author Share Posted August 7, 2008 will be getting two gemi crossmembers done two sets lower and two sets upper a arms, sway bar cups bumper brackets engine mounts sump, diff housing once its shortened and lower arms etc will have to get it all out and take some pics when its ready, will use forlong maisey likely in te rapa hams Quote Link to comment Share on other sites More sharing options...
