Esprit Posted November 25, 2008 Share Posted November 25, 2008 Oh, and speaking of ECU bodges, nothing could be more Bodge than the Factory ECU I'm running.... it's a re-wire of the Lotus ECU for the Esprit V8 Twinturbo.... plug it into the diagnostic machine and it tells you that you've got a serious misfire in cylinder number 8... quite a feat for a 4 cylinder car! Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted November 25, 2008 Share Posted November 25, 2008 hmm was the e spree flatplane crank ? .... its funny how stock ecu setups work lots of toyota's run the same trigger setup 24/2 even the uz is a 24/2 setup so as long as you can get the base timing set you pritty much swap them ive put a 4agze ecu on a 4afe (diferent head ..) a 3sgte on a 4age ... and ... by swapping map sensor and injectors .. made a 1jzge into a 1jzgte... and if you use those same calculations on the 4age/ 4agze ecu ... the 4agze injectors are ruffly what it would take to do the same swap on a a 4age...... with the ge computer (early gze motors were also distributed) i prolly need to spend more time making something worthwhile than just playing with shit to see if it can be done BTW i have a storm in my hilux...... so if your around ill chuck on the laptop and you can have a play Quote Link to comment Share on other sites More sharing options...
Spencer Posted November 25, 2008 Share Posted November 25, 2008 hmm was the e spree flatplane crank ? .... i I thought no, but after hearing a few think they may have Quote Link to comment Share on other sites More sharing options...
Esprit Posted November 25, 2008 Share Posted November 25, 2008 Esprit was flatplane crank yeah... it's basically two Lotus 910 Twincams on a common crankcase, very cool engine that. Cool Wayne... I'll have to do my reseach on ECU choice... until now I'd just assumed Emerald because it was the default choice, but if I can see a convincing argument to go otherwise then that's where I'll go Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted November 25, 2008 Share Posted November 25, 2008 kk yeah flatplane would make sence for a ecu swap... well in my head no worries mate ecu's have changed a LOT in the last 6 months so there is a lot of reading to do ... ops winnie just txt back... cufuzzed as fuck misson successful Quote Link to comment Share on other sites More sharing options...
V8Pete Posted December 14, 2008 Share Posted December 14, 2008 Plz Quote Link to comment Share on other sites More sharing options...
Esprit Posted December 14, 2008 Share Posted December 14, 2008 Plz Hahaha nice! My warnings are a little more subtle, but then again I'm thinking about the weight too! I'll also be doing without the condiment dispenser on the pax-side dashboard that that car has... my passenger can organise their own ketchup/mayo/mustard thankyou very much! Quote Link to comment Share on other sites More sharing options...
