d.p.n.s Posted June 19, 2008 Share Posted June 19, 2008 hi all finaly got my driveshaft made for my van and just took it for a drive seems ok till i take my foot of the pedal and it starts whinning and making soundslike the tyres are rubbing or driveshaft is rubbing the underside but they arent. any ideas diff,bearings? cheers dan Quote Link to comment Share on other sites More sharing options...
Guest hotrod.mad Posted June 19, 2008 Share Posted June 19, 2008 hmmmmmmmmm thrust bearing /does the sound stop when the clutch is pushed in has the diff got oil it will need to be changed if its been sitting /check the seals around the axels/or its about to blow id say the oils fucked and its basicly water now let me know and ill send you another one bro Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 19, 2008 Author Share Posted June 19, 2008 ill ckeck if its the thrust bearing tommorw. next time your under those to lovly escorts of OURS see what the diffs are. cheers Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 19, 2008 Share Posted June 19, 2008 Are you saying that the noise (and vibration??) are only on over-run? It won't be the thrust bearing if that is the case and is more likely the diff pinion bearing - which is sort of common on small Ford diffs. A diff head change should only take 90 minutes or so. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 19, 2008 Author Share Posted June 19, 2008 yeh whats happining uj is if i take off it drives ok can change gear but if i take my foot of the go pedal and while its slowing down its making the noises. cheers dan Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 19, 2008 Share Posted June 19, 2008 my old rx7 did that,then one day i went for a drive and it went bang and you could hear the pinion spinning on the crownwheel. turned out the pinion bearing was buggered and caused the pinion teeth tips to wear out and there was nothing left to grab...luckily i was only 200m from home.. Quote Link to comment Share on other sites More sharing options...
Guest hotrod.mad Posted June 19, 2008 Share Posted June 19, 2008 ill have a look for you fuck i didnt even think about the pinion in the diff yeh ill check for you bro Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 19, 2008 Share Posted June 19, 2008 I second pinion bearing. (or is that third?) Quote Link to comment Share on other sites More sharing options...
sholdowa Posted June 19, 2008 Share Posted June 19, 2008 I've got a spare diff - 3.9 I think - but there's not way I'm carting that in on the bus... Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 19, 2008 Author Share Posted June 19, 2008 I've got a spare diff - 3.9 I think - but there's not way I'm carting that in on the bus... lol ill see what my brother comes up with mate but as always steve ill keep you in mind for my escort parts have you started on yours yet man? Quote Link to comment Share on other sites More sharing options...
