1300 help
Guest Westmk2
Guest Westmk2
The 1300 in my escort is running abit weird. so here is the story. Coming back from work yesterday on the motorway, in fourth gear going about ninety k's the revs like halve and then the gear shift starts vibrating and i hear loud splutering from the engine. It only happens when i go up a slight incline and then when i go back down the hill it works fine. I have no idea what the problem is, maybe the engine is getting to cold cos of the cold air? The temp gauge reads like 60-70 when im on the motorway. Help would be sweet :) Chur
I'm guessing like Gaz it's a fueling issue. It's a wee bit of a pain but next time it happens and you can do it safely, turn the key off and pull a plug or 2. If it was missing due to over fueling the plugs will have a light deposit of soot.
Does it always do this or does it only do it sometimes?
If is is consistant that the angle of the car seems to be making a difference this is a clue that should help diagnose the fault.
Check your plugs like Uncle Jake said becasue it could be as simple as when you are on a hill the coil lead is loosing connection or it's crapping out and when you are going up hill it's touching something and leaking current.
I'm not good with carbs so this is a stab in the dark but I'd check that the float bowl level is set correctly. It could be that the fuel bowl is getting over full when you go up a hill and it's casuing it to run way rich. This is why I'd check the plugs for running rich when the issue is happening...
Guest Westmk2
It seems to be happening more and more often. Ill pop the bonnet today and have a gander. Thanks guys for your help :) Ill let you know how it goes. :D
Guest hotrod.mad
i had one that did that years ago i changed everything and it turned out the coil was on the way out check if the coil gets hot or is leaking other than that fuel pump about to shit its self or float in the carb is jamming on inclines :twisted:
