d.p.n.s Posted May 19, 2008 Share Posted May 19, 2008 hi all does anyone know if nolathane do the rear bubbers for a escort the ones that go between the diff and leef springs they have a metal ring around the top where the diff site and both of mine are totaly fuked unless some one has some sitting around they want to sell. cheers dan Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 19, 2008 Share Posted May 19, 2008 Take them out. Its one of the things the Rally prep guide does first to mod rear end. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 19, 2008 Author Share Posted May 19, 2008 Take them out.Its one of the things the Rally prep guide does first to mod rear end. what just take them out and not use them ? Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 19, 2008 Share Posted May 19, 2008 Also do you have upright shocks or shocks on a 45° at rear? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 19, 2008 Author Share Posted May 19, 2008 Also do you have upright shocks or shocks on a 45° at rear? i did not know that mate. cheers and my shocks are at 45. Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 19, 2008 Share Posted May 19, 2008 Uprighting them is a good upgrade I am told, but not the easiest. Also removing a rubber mount at the top end where the shock mounts is prob worth doing if you do the above. Might need slightly larger lowering blocks also as it'll make your car a tad higher. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted May 19, 2008 Share Posted May 19, 2008 Your not building a rally car though are ya? For ride comfort and the hasel of changing ride height just go to bnt and get some new noltec ones, called a sandwich pad, theyre not that expensive, i done my hole car. Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 19, 2008 Share Posted May 19, 2008 For the comfort reason perhaps a good idea. Only do it I guess if you want it to handle slightly better. It will stiffen up the rear end, prob make some new noises too haha. Quote Link to comment Share on other sites More sharing options...
peteretep Posted May 19, 2008 Share Posted May 19, 2008 im sure a nolathane one wouldnt give much movement how much were the pads from bnt? Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted May 19, 2008 Share Posted May 19, 2008 when i put altas in my esky i made it fit with out them, have to say i cant think ov any increase in noise or vibration. remember the diff os bolted to leafs and they are rubber bushed to body anyway. Quote Link to comment Share on other sites More sharing options...
sholdowa Posted May 19, 2008 Share Posted May 19, 2008 For the comfort reason perhaps a good idea.Only do it I guess if you want it to handle slightly better. It will stiffen up the rear end, prob make some new noises too haha. Comfort in a van! Harden up! We just threw them away, and then used washers under the bolt through the spring leaves to build a pin the right size to locate the axle. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 19, 2008 Author Share Posted May 19, 2008 For the comfort reason perhaps a good idea.Only do it I guess if you want it to handle slightly better. It will stiffen up the rear end, prob make some new noises too haha. Comfort in a van! Harden up! We just threw them away, and then used washers under the bolt through the spring leaves to build a pin the right size to locate the axle. lol . yeh i think ill just do away with them i mean it is a van ..... Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 19, 2008 Share Posted May 19, 2008 Sweet next time im under my car i will throw mine away also could help the rubbing problem a little also. Anyone know a good place to find new nolathanes for gearbox crossmembers mine is fuckt. I havn't tried collins yet but guessing they may. Quote Link to comment Share on other sites More sharing options...
peteretep Posted May 20, 2008 Share Posted May 20, 2008 suspention tech do nolathane gbox mounts, $165 exchange I think Quote Link to comment Share on other sites More sharing options...
