15's on an Escort
two_days_late
hey boes
Hopefully my cars gonna start gettin paneled in the next couple of weeks (once WDE_BDY gets the Uterus out of the shed) and i just wanna find out about the wheels before the guards are flared.
I've got bolt on fibreglass flares and im lookin at TSW Apex R's or something similar (any other ideas coz im not 100% sure?, would also like something with some dish but new school). Will be lookin around 40x215 (rear anyway) for tyres. The inside of the guard will be rolled anyway but just wonderin if anyones got any advice about rubbing or whether they look stupid?
Cheers
Matt
p.s Mk2 escort coupe
  • Replies 53
cant say bout mk2 but my mk1 rubs like a bitch on back right wheel with lipped guards when theres weight in the back. left side is just ok. weird, maybe axels arent matched or something. however i "think" theyre fwd rims as the front just barely clears the struts, like up to 10mm. oh.. ROH extremes
surely youll be all good with rolled flares no matter what you put on. got a pic of those rims?
MK2s (excluding vans and wagons) have a fair bit more room in the guards than MK1s, so you may get away with just a good lipping on the guards.
If your going to fit flares cut the old lip etc off and reweld the inner guard back onto the outers.
I'm not sure what look you are after but in my opinion, when you have wide guards (bolt ons or such) you need to have wide and probably smaller wheels to fill them. They need to go right out on to the guards, otherwise it doesn't look quite right.
Example. Z with bolt ons and a 0 or negative offset wheel.
http://www.classicdatsun.com/new/432flares-blue1.jpg
Now, if you want to rock those wheels which are larger and more than likely, a more positive offset (fwd offset) they will sit in quite abit and not look right because they won't be sitting on the guards and the car will look wrong.
Shit, I can't find an example of that because no one does it lol. But yah. Hope that makes senSe.
Apex R's
also like this kinda style for a bit of dish...
Cheers for the advice, will definatly be putting on the fibreglass flares and my panel beater said he has a tool for properly rolling the inside, just wanted me to check if anyone else has had trouble with rubbing.
The 15's with 40profile should work out about the same size as the factory 13s with 60 or 70profile accoring to the calculators on the net.
Cheers
Matt[/url]
yea fully agree Mikuni, that datsun looks good like that.
any ideas on some wheels that are a similar style with a more rear wheel drive offset? only so much fat tyres can do! need something to full the guards up.
flares are bolt on but will be fibreglassed to the body, its a reasonably mild flare too, not forrest or xpack or anythin.
cheers
matt
eskyag5.jpg:oops:
Its up to you, but i would seriously recommend cutting a fair bit of the stock lip off, or at the very least flaring the stock guards right out before fitting the F/G ones!
true, haven't looked that deeply into it but even 45s would be mint.
Yep Yep, my panel beater seems to know what hes doin so he should be able to roll them out, or cut them if he has too. should really buy the wheels first.
Anyone got any ideas on some otehr styles? Car will be metallic blue (blueprint falcon blue) if it helps.
Cheers
Oh right, i should have clicked that the roller was yours. If getting tyres wide enough to full out the guards meant i had to goto a slightly higher profile i'd have to really. Biscuts under big guards look stupid as.
The 70s looking pretty nice huh, i quite like those wheels you've got on it. Were those workshop manuals any good?
Matt
Where is the car? Ya can borrow one of my 15's if you wanna do some playing/check whats what.
Id recopmend buying the rim first and the tyre then making them fit/not scrape at the desired height... then flaring and painting. Mk2 gaurds are ALOT bigger than mk1 but still you may need a bit of flaring... Dont do what I did and do the paint first.
I got three sets of 15's in 4x108 pattern,
15x6.5's with 195/50/15's, you can go 195/45/15 of trademe for $105 a pop
15x7 with no tyres but FWD offset for use with hilux diff (prob no use to you)
15x8.5 RWD offset with 205/50/15
15x7.5 with 185/60/15.
Any of them usefull to ya?
PS. The TSW Volcano (the one with a bit of dish in ya pics) is a good rim but dont have as much dish as shown in the pic.. youll prob find the one in pic is a 18 or 19 or sumthng with more dish than the 15's. Mate in Welly has some 15's for sale but he wants alot for them...
Another option is run 16's... 195/40/16 is easy to get to keep rolling diameter roughly same as a 15.. 16's only a tad more expensive too.
Gaz
