Smit Posted July 24, 2007 Share Posted July 24, 2007 must have drawings/diagrams will give a quote plus any welding needed to be done!!! let me know... for eg: turbo manifolds, extractors. cheers Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 24, 2007 Share Posted July 24, 2007 Hrmm might as well get a quote since im about to orser manifolds from overseas. 1. ca18det lowrise manifold stainless 2. ca18det highrise manifold mild or steam pipe. Both need external wastegate flanges Thanks Also can you weld a wastegate flange directly to the housing for me? Quote Link to comment Share on other sites More sharing options...
pies Posted July 24, 2007 Share Posted July 24, 2007 Hrmm might as well get a quote since im about to orser manifolds from overseas.1. ca18det lowrise manifold stainless 2. ca18det highrise manifold mild or steam pipe. Thanks x2 but highrise with external wastegate flange Quote Link to comment Share on other sites More sharing options...
durty Posted July 24, 2007 Share Posted July 24, 2007 what tools you have? assuming you can tig? Quote Link to comment Share on other sites More sharing options...
Smit Posted July 25, 2007 Author Share Posted July 25, 2007 ofr the ca18det manifolds need original manifold to jig from... but can do, have done sr20det ones in the past can show photo. as for welding a wastegate onto a cast iron existing not worth it as will crack. so not worth it........ can def tig can do all welding. cheers it is actually my flatmate but is an engineer so you name it doesnt have to be just to do with cars.... cheers Quote Link to comment Share on other sites More sharing options...
treggo Posted July 25, 2007 Share Posted July 25, 2007 soon i will need a simple manifold to fit yamaha r1 carbs to my pinto. stainless if possible only needs flange at one end. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted July 25, 2007 Share Posted July 25, 2007 might come see you n a couple of months time. need an inlet manifoldmade up form stainless or alloy. choice Quote Link to comment Share on other sites More sharing options...
durty Posted July 25, 2007 Share Posted July 25, 2007 true, i may be needing a bunch of work done, not for a little while tho shortened and welded sump and oil pickup, custom turbo manifold for 5 cylinder cut and shut inlet manifold etc Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 25, 2007 Share Posted July 25, 2007 as for welding a wastegate onto a cast iron existing not worth it as will crack. so not worth it........cheers It can be done. Seen it done many times in pics and twice in real. Guess ya need the right rods etc, im unsure. Anyways, if that's a nogo how about fixing a wastegate flange to an existing stainless manifold? Price? Cheers Quote Link to comment Share on other sites More sharing options...
Grotty Posted July 29, 2007 Share Posted July 29, 2007 as for welding a wastegate onto a cast iron existing not worth it as will crack. so not worth it........ It's sweet to weld to cast, you just have to have the know how to make the metal work for you. Have done a lot over the years for work, easy fast and cheap way of fitting an external. When done right it will not crack!!! Plus you get the bonus of keeping the cast manifold as most people just daily drive their cars, not race them or show and shine! Quote Link to comment Share on other sites More sharing options...
m house Posted August 1, 2007 Share Posted August 1, 2007 very easy to weld to cast do a bit of it u use high ten 8 arc rods and pre heat the steel and pen it. shouldent crack if u call yourself a welder. any 1 wont any CAST welding done ill do it 4 nothing tur. millz Quote Link to comment Share on other sites More sharing options...
Smit Posted August 1, 2007 Author Share Posted August 1, 2007 i am aware of the process in welding cast iron but even then it isnt guaranteed... can be very temperamental when constant heating and cooling is involved. would rather not do it as i cant guarantee it isn't gonna crack. if you wanna do it be my guest. more experienced in stainless,aluminium and steel have done cast iron in the past but is not my preference.. cheers Quote Link to comment Share on other sites More sharing options...
