oh my bad,even still gaz i would rather go with a excedy they kane
take a fuckn raping, they make sum good clutchs, i would stand by them,
my 2 sense worth any way,
millz
gaza, cheap dose not = good
if i was you i would stick with wot i no,
my m8 has a f1 clutch set up in hiz kar
and it cost him a pretty penny,
if they were that good u would have herd about them
and ppl would have them, myself i wouldnt buy a heap
of shit f1 rip off clutch thats gana shit its self afta a hard
day of raceing/burnouts
millz
illd run with the 12a decomp rotas
then u kan bolt a turbo on the side if u hav the need
dosent mean any thnk if you roll a 12a decomp engine
i do , if its that bad i make better power than sum 12as with
i ida,,
cheers millz
grants automotive in whakatane
12a monster brige rebult fully workd 4banga massive
jets all the bells and whistles
poretd exhaust maifold wound the fuel presure mack daddy tune
by guys who no wot they r doing that holds the fastest na rota in
nz.but yea lsd is getin shorten and put in when i get time
keeps cunts honest
cheers milz
thats the best way drill the driveshaft holes out and
the diff head holes out 13mm hole in both use 12mm
h/t bolts with nylock nuts with locktight easy az
ive done it swt ha drive shaft hasnt kum out of my esky
and i do 8-9000 rpm swing os haha swet miilz
any one need any thing done,
any welding s/s,aluminuium,m/steel, cast
drawings/diagrams would b a plus
cheap as chips 15 buck a hour plus materials
thats if i dont have it cost me nothing,swt swt millz
very easy to weld to cast do a bit of
it u use high ten 8 arc rods and pre heat the steel
and pen it. shouldent crack if u call yourself a welder.
any 1 wont any CAST welding done ill do it 4 nothing tur.
millz
